SOURCE: code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
SOURCE: Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
try this then service request http://www.konicaminolta.com.au/products/164/magicolor-Printers.aspx?gclid=CKSrk7LCn60CFQZLpgodGFVynQ
