The condensate drain line normally runs thru the engine compartment firewall on the passenger's side. about halfway down. Look for a rubber hose protruding out through a rubber grommet. The "water" you are getting could be from one of three sources:
Feel and smell the liquid. If it smells sweet or has an oily feel, it may be engine coolant. If it is, you most likely have a heater core that is leaking. Hopefully that is not the case. Otherwise, clearing the clog from the drain line should help solve the issue.
