Whirlpool Duet GHW9150P Front Load Washer Logo
Linda Aske Posted on Sep 08, 2015
Why did it chew up my clothes? - Whirlpool Duet GHW9150P Front Load Washer
When u put a washload on. Is it ok to fill the drum with your clothing or best to leave about 6 inch gap. Also getting little brown bits like leaves on our clean clothing Please help me ??????
It's always good to leave a little room for clothes to tumble. As far as the tiny leaves it might be a gasket going bad being chewed up bit by bit..
May 10, 2018 • Dryers
2answers
How to get bubble gum out of car floor mats
Hi, rub a piece of ice over the bubblegum until it is solid, then pull off.
Is there a fix for the washer it's chewing my towels
This washer is known to eat some clothes.
I found a great big silk pillow case between tubs once:
Most of the damage is done in the beginning of the cycle directly after the brain has re-destributed the clothes. Any items of clothing with strings need not be washed in this machine or the strings will get into the pump:
I wrote an article for FY on these:
http://www.fixya.com/support/r5224450-calypso_repair_manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Our washer is cutting our clothes.
Possible that there is a gap in the spinning agitator that seems to chew up the clothes to damage.
SO if you notice this gap then remove and reset the spindle.
if not make sure that the drum pores have some sharp edges which is tearing , run your hands/palm over the drum for a suspected abrasive edge.Can be some objects that have lodged into and causing to behave as a knife edge.
1helpful
Hi i have a whilpool 5132E top load washing machine i bought second hand, my cloths collect fluff, especially the towels. Does thi model have a filter.thank you chrissie
no but it sound like the agitator has a sharp edge and chewing up the cloths feel your finger all the surface area of the plastic and feel for a gouge or rough area then get sandpaper or other type of item that will smooth it out and that should stop the fluff issue
Chewing gum throughout interior of clothes dryer
THERE IS NO MAGIC BULLET FOR THIS. MAYBE A RAZOR BLADE SCRAPER AND PATIENCE. GOOD LUCK
Apr 17, 2009 • Dryers
Hotpoint FEW12 washing machine chews up clothes
If you check the door sal and there is any play in it then it needs replacing. Mine had two saggy indent bits and needed changing..no more ripped clothes
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
