Washing Machines Logo
Posted on Sep 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix my top loading Kenmore washer?
Kenmore model# 11028002011 Top Load Washer, push button to start machine.It powers on,lid lock clicks,clock begins but no water fills and it doesn't advance to next process. tried unplugging and plugging back in, nothing. Restarted to drain and spinsince there was still water from last cycle, nothing. Not sure how to check for error code or if you can even check for error code on this model. Any advice would be greatly appreciated.
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Sep 29, 2015
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626098
Points
28464
If the lid is locking then you have a control board issue and it will need to be replaced. Here is a link to that part. http://bit.ly/1L1fNqO
  • Steve Oglesby
    Steve Oglesby Oct 14, 2015
    I have the same washer it lights up but it dose nothing not even lock lid
I need the repair manual for the Maytag commercial technology top load washing machine
No model number, so generic answers
https://www.manualslib.com/manual/913203/Maytag-Washer.html
The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area. Please check the lid lock area and remove any objects in that area.
Jun 22, 2021
F5 E2 Error code for top load washers - Product Help ' Maytag
https://www.google.com/search?q=maytag+commercial+technology+top+load+washing+machine+f5+error+code
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Model WTW4800XQ Whirlpool top load washer will not fill. Only hums when on button is pushed. what is the problem?
Does it do it on hot and cold water. Check the water filters where the hose screws on to the washer.
4helpful
2answers
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
The agitator won't work, and the button under the lid fell off. What can we do to fix it, or would it cost too much to fix it?
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
IF THIS IS A BASIC KENMORE / SEARS TOP LOAD, DIRECT DRIVE WASHER THE PROBLEM IS LIKELY A LID SWITCH. (EASY AND INEXPENSIVE TO FIX)
I'D NEED TO KNOW THE BRAND AND MODEL NUMBER TO BETTER SUGGEST A SOLUTION.
Power comes on and all lights come on, but the washer will not start the wash cycle. After the start button is pushed the lid lock will not lock.
That is why the washer won't start. Replace the lid lock. It is there to stop anyone from putting their hands inside of washer when it ia agitating, by stopping power to the motor.DO NOT try ANY attempts to mmake it work!!!! Injury may result
When you push start button error message says lid. Washer will not work.
Lid switch failure or out of adjustment, if your handy pop the top and adjust or replace the lid switch, or call your local authorized Kenmore servicer.
Good luck !
3helpful
Kenmore top load washer model 110.44722401 won't start
The Machine does not know the lid is shut.... there is an arm connected to the lid... that arm runs just inside the the top cover and presses a button to signal the lid is down.. some where along the line the arm isnt pushing the button..take off the top cover and it should be an easy fix
1helpful
I have a Kenmore issue
get a putty knife and come over about 2inches from the front edge and push in between the top and cabnit should feel a spring retract at the same time your lifting the lid do the otherside and raise the top the push the hook back on the latch and raise the lid then replace the lid lock switch
Alexander
vince
