Question about Dishwashers
How do I fix a jammed door latch on an older hot point dishwasher
Hot point dishwasher over 25 years old
    New Friend:
    Problem Solver:
  • 5 Answers
Do not loosen any screws.
Posted on Sep 07, 2015
SOURCE:
I have a kitchenaid KUDS01DJSS0 DISHWASHER THAT WAS MAKING LOUD WHINE NOISE..
you are better off getting a new dishwasher which is more water and elelectricity efficient. around 10 years is a good life and it will be putting good money aftger bad.
Jul 18, 2012 | KitchenAid Dishwashers
My Hot Point Dishwasher is leaking water. It was
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have a jackson Low Temp single door model.. I
you may need to clean out your hot water heater depending on how old it is and yes 80 gal should be more than big enough adj. thermostat to the next level
Jun 09, 2010 | Jackson 25 in. Conserver XL Free-standing...
The door is open and the lock latch is locked how do i release it?
the part on door that seats in the door striker on car door jam....move it with a screw driver be gentle it should move with out any force harder than a 7 year old could give it
Nov 22, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Older whirlpool dryer gets too hot when using automatic setting
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Nov 26, 2008 | Dryers
Whirlpool ADG993
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Dishwashers
The cover of the detergent dispenser does not latch properly and will flip open. The dishwasher is 6 years old and I think we need to replace the dispenser assembly but don't know how to take it off the...
I've posted this before. The latch just needs a good cleaning. In the past, something placed in the washer kept the door from opening properly, which caused detergent to dry under the latch. This has happen several times until I figured it out. Don't block the opening with tall objects. Soak or repeatedly apply hot water and a little brushing and it will be fixed. It doesn't happen anymore.
Denise
Jul 01, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
