Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine Logo
Anita Ross Posted on Sep 06, 2015
Connection error, check usb cable....
I have the original cable, I purchased a cable and I still get the error message. When I unplug and plug the cable (either machine or laptop) I get the sound of connection but when I try to open software I get the Connection error and the check usb cable and power message. Help please.
  • Anita Ross
    Anita Ross Oct 03, 2015
    Thanks, I had the wrong USB cable.
Mary Doss
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Oct 03, 2015
Mary Doss
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
12258
Points
38
This may sound silly and I am not trying to be a smarty but mine does that quit a bit and it always because I don't have the on switch on when I pull up my soft ware and if the cord you bought is to long it will not work I suggest only because i do this frequently go back to the original cord hook it up turn it on then pull it up on your computer
1 Related Answer
Anonymous
  • 64 Answers
  • Posted on Jan 22, 2010
SOURCE: Singer CE0100 Futura connection error....
newtosinger, you got a very strange answer. Updates with 64bit Vista/XP and Windows 7 platforms support will be released for all Futura models, just due to higher demand updates for newer machine models are released first. So far updates exist for models ce150/250/350 and ses1000/2000. In a few days will be released an update for ce100/200 that use software 2.5.0.0-2.5.0.2. After that will be released an update for older software versions Futura 1.0.0.x (ce100) and 2.0.0.x (ce200/200E)
Uploaded the futura ce350 software on windows 7 several times. When open programme get an message: Connection error.Check USB cable is connected & power switch is turned on.
There are a few possible reasons to get the USB connection error. You could have a bad USB cable, a bad port (on the computer or the sewing machine). If you are using a USB hub, try a direct connection. Try a different USB 2.0 cable (type A to type B) of 6' or less in length connected to a different port. You might simply be opening the program before the driver is completely installed. Wait a few minutes after turning on the sewing machine; look for the New Hardware Found message disappear indicating that the new driver has been associated the USB device. Usually the new hardware found is announced with a beep.
If you are connected to a USB 1.0 port, you need to turn off the computer, connect the sewing machine's USB cable to both devices and then turn on the sewing machine. Then turn on the computer and wait for the driver to be installed completely. (The first generation USB protocol was not plug and play. It only recognized devices on restart/boot.)
To check if the driver for the sewing machine is found by the computer, open the Device Manager. Expand the Human Interface Devices section. If the entry for the CE-350 has an exclamation point or a red x, the driver hasn't been properly installed. If you right-click on the device, choose Properties. Check the General section to see if the computer thinks it is working. Look the events tab for details like a "Further Installation needed" message.
I hope this helps.
(Note: some USB ports do not hold the cable properly. If the cable is wobbling in the port, you might hear the Hardware found beep several times as the connection appears and disappears with the machine. Under some circumstances, the port can be damaged by high voltage demands (charging with a bad cable or too many devices on a USB hub) or a surge coming through the computer. You can sometimes check this by connecting a USB device that works on another port or machine to the port that may be faulty.)
I have a Singer Futura Quartet and when I try to use the embroidery function I get an error message that says my machine is not turned on or the cable needs to be connected. everything is connected
If your computer indicates that there's no USB connection to the machine, and therefore the Futura program refuses to start, there are several possibilities. The most likely is your cable is bad, although I have had USB cables that worked fine elsewhere, but didn't on the machine. Try switching the cable you're using with your printer cable.
Sometimes if you originally installed it using one USB port, it doesn't want to work if another port is used. Although I have not had that problem on this line of Futuras, others have. Try switching the port you're using.
Another possibility is the USB plug on the machine doesn't "seat" very well. That's true of all the Futuras. Make sure that the plug is sitting squarely in the machine. Personally, I tape the plug in using masking tape, then plug and unplug it from the computer side.
Singer futura quartet connection error
I need more information to answer this question. Is this a error message on your computer screen? Or on the machine? I know Singer Futura machines require a USB cable connection to work; check USB drivers are installed properly on the compatible version of windows as well.
Cheers,
Embroidery Services
San Diego, CA
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
4answers
Machine keeps stopping and says to turn it off
Hi. Is there an error number on the screen? may i have the exact error message that appears on the screen.
2answers
When I try to open the futura program a pop up box continues to say check that USB cable is attached and machine is turned on. I tried two different USB Cables and turned the machine on. However the same...
My computer is extremely touchy when I use my usb cable to attach to my machine. I have to use the SAME usb port that I used when the driver was installed or else it will not recognize that my machine is plugged in. Basically it is telling you it cannot find your machine. Reinstall the driver and mark which usb port you used to install the machine.
Also, in order to open the futura software, your machine must be powered on and connected via USB cable before you attempt to open the software on your computer.
1helpful
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
9helpful
4answers
So here's what I did and it worked for me. Somehow the WinDriver that is on the software is uninstalling itself and needs to be listed with the drivers for Jungo for this software to work. I installed the software when I first got the machine with no problems, then suddenly I couldn't open it and was receiving the same connection error. When you go to http://www.futura-support.com/faq/machine.htm#2 to install the drivers, you'll notice their screen shot shows both the CLEM driver and the WinDriver. Check your machine following their instructions to see if you have both listed under the Jungo driver. If not, go to http://www.jungo.com/st/windriver_usb_pci_driver_development_software.html and select the link under "Available WinDriver Toolkits" for your operating systems (I selected WinDriver USB for Windows). It asks a bunch of questions which I didn't know the answer to so I selected "other" on almost everything then entered "NA"or "?" for the other description. Select Download now and it will need to restart your computer. Once done, I looked at the device manager again and now WinDriver is listed under Jungo and CLEM and the software opens, no problems.
This will at least temporarily solve the issue, however, it's a free trial which means the download will expire at some point. Good news is, the windriver is on the futura disk, I just don't know why it's not installing or staying on the machine. I am sending all of this to Singer to figure out what they're missing in the installation files and hopefully get a fix permanently.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
