Depends.
There are doors that control air flow and temp. Some are moved by vac and some use small electric motors depending on which door and if you have manual or automatic climate control.
You would need to take the trim panel off under the dash and probably open the glove box all the way to be able to see the components. The one that controls air flow is probably stuck or otherwise not moving.
SOURCE: 1998 Mustang - AC blows only through Defrost vents
You probably have a vacuum leak on the passenger side. its a small plastic hose some times they come unpluged from the engine. or brake.
SOURCE: No air flow from defrost vent on my van.
Could be a vaccum line leaking not changing the vent flap to defrost
SOURCE: Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
SOURCE: AC NOT BLOWING THROUGH DASH VENTS
PROBLEM COULD BE BLEND DOOR ACTUATOR OR FAULTY AC CONTROL MODULE.
