I need to change the fuse in my machine because it won't turn on. Please help. Thanks
There are no fuses on these machines. If it is not getting hot and making your coffee it is because the heating element is open and needs to be replaced.
The problem is that the machine is not turning on at all
If it is one of those fancy machines that goes thru an electronic controller then it is important for you to check the power supply area of unit. It feeds the control board components and powers any relays.
Follow the power line and see exactly where it goes...If there is going to be a fuse it has to be right around that part of the board where the power line enters. But if there is a fuse and it has opened, chances are that there is something wrong that caused the fuse to open - after all, that is its job.
