LeapFrog LeapPad2 Explorer - Green Logo
A
Anonymous Posted on Sep 05, 2015
Will not charge. Orange light keeps turning on and off.
DS Lite screen won't light up
your battery is very low. Charge the battery for 3 hours. you can still play games, while it charges.
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
2helpful
2answers
Fully charged..why is the orange light flashing
could be that you are used to keep the laptop connected to the ac powerall the time, and the battery slowly died every day, and now it's to the lowest level it could be.
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Ipod shuffle
the light blinks until its completely charged u know this when the light turns green u have to keep the ipod off while charging
5helpful
3answers
Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
