actually took unit apart found a sensor that seems to have coorroded that was clipped on the side of coils was just hanging should it be touching the coils it looks like it should from the corrosionactually took unit apart found a sensor that seems to have coorroded that was clipped on the side of coils was just hanging should it be touching the coils it looks like it should from the corrosion
In the spring time of the year, the dehumidifier ices up I know the temp/humidity is below spec because the humidistat is just next to coils, not installed as it should be. The Humidistat is rusted.In the spring time of the year, the dehumidifier ices up I know the temp/humidity is below spec because the humidistat is just next to coils, not installed as it should be. The Humidistat is rusted.
You can't post conmments that contain an email address.
3 things could cause this. 1) The humidistat has gone bad and not cycling off (running too long). 2) Not enough humidity in the air. 3) Condensor coils are too dirty (causing it to run too long).3 things could cause this. 1) The humidistat has gone bad and not cycling off (running too long). 2) Not enough humidity in the air. 3) Condensor coils are too dirty (causing it to run too long).
I think a part of the problem is that you have the humidity extraction level set to high. 50 to 60% is pretty much the humidity level throughout most of the year. Lowering it to 35%m should make a difference.
If you are using this in a basement application, the temperature at floor level can be 10 degrees cooler than at shoulder level. Most dehumidifiers don't work well at temperatures between 40 & 60 degrees F. Unless, they are Low Temp models designed for basement applications. Raising the unit up off the floor onto a sturdy table, counter top, etc. That can handle the weight of the unit, plus a full tank of water can resolve this problem.
If you can access the cooling coils, they may be dirty and need wiping off with a damp rag. Then flow with a dry clean rag to dry them. A light coating of WD40 helps to preserve the coils.
I hope this helps you to further troubleshoot and solve the problem. Thanks for choosing FixYa.
You may have the humidity level set to high. Keep in mind, the higher the number on your LED screen, (if your units have LED display) the more humidity remains in the house. Lowering the numbers on the screen (to 45%), should have a better affect.
Hi, Dehumidifiers freezing up can be causes by a few different problems. Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site. You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Clicking on the underlined links will take you directly to that page.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Some models utilize a defrost thermostat that simply switches the compressor off and on. This can be replaced by unsnapping it from the condensor coil.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue. Thank you, Dave E. (Illeagle) "Your satisfaction is my personal reward"
Dehumidifiers and how they work Heat pump dehumidifiers
Dehumidifiers use a heat pump (similar to an air conditioner's heat pump) or chemical adsorbents to remove moisture from the air without cooling the air.
A heat pump dehumidifier uses a fan to draw indoor air over a heat exchange coil. The coil is almost freezing. The water in the air condenses on the coil and is drained. A second heat exchange coil reheats the air, which the dehumidifier exhausts into the room.
A heat pump dehumidifier dumps heat lost from the compressor and fan motors into the air. It returns to the indoor air the heat generated by the dehumidifier turning water vapour to liquid. I got this off the internet
I have the same dehumidifier and it does the same thing. but I was able to fix mine. It was not low on refridgerant. There is a temp. sensor clamped to the evaporater coil with a thin metal clip. The clip rusted out and the sensor fell out of position. I used a small stainless steel hose clamp and clamped the sensor back into position. It now works fine
sorry this is a dehumidifier
