If its still is defective in a corner or in the attic? Maybe you can make info by a KLIPSCH service centre because Klipsch is the owner of JAMO http://www.jamo.com/about/ if you have not find the answer.
Jamo About
SOURCE: Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
SOURCE: cant connect jamo sub 250 to marantz SR4001
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
SOURCE: JBL sub PSW-D110 hums, and the fuse is blown
Try replacing parts listed below first. Less that $10.00 C6 kit as an substitute and the parts are as follows: The part is available The part is called: CAP RAD 10uF 100V Bi Polar. BU120/BU80 The Part # is: UVP2A100MPD The price is $2.70 each, plus shipping and handling (For U.S. orders only). The part is called: RES CF 20K OHM 1/2W For C6 kit The Part # is: 293-20K The price is $1.98 each, plus shipping and handling (For U.S. orders only). The part is called: RES mf 47R OHM 1/4W For C6 kit USE -RC The Part # is: 271-47 The price is $1.98 each, plus shipping and handling (For U.S. orders only). The part is called: CAP MCER AX 100NF 50V For C6 kit The Part # is: 75-1C10X7R104K050B The price is $1.90 each, plus shipping and handling (For U.S. orders only). The part is called: Instructions, Kit (C6 repair) Gen brand The Part # is: C6KIT INST The price is $2.01 each, plus shipping and handling (For U.S. orders only). If you are not in the U.S. please advise where you are so the correct information can be sent to you. Please add tax if you live in New York (8.25%), New Jersey (7%), Connecticut (6%), California (8.25%), Florida (6%), Arizona (8.10%), North Carolina (7%) & Georgia (7%). You can order this item by calling us at 800-422-8027, 800-336-4525 and 800-553-3332 Please allow 7-10 business days for shipping
SOURCE: The fuse of Jamo Sub-200
blown fuse indicates that current drawn is more then fuse's limit. there may be integrated ic failure or any other short circuit in amplifier. u need to check with a multimeter where is the short circuit.
