Golf Logo
r
robert nienaber Posted on Sep 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I connect 36 volt battery charger to electic golf cart?
Black and white wires neg and pos polarity plus a red wire that does not hook up to dc plug ?
Ronald Prier
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Sep 19, 2015
Ronald Prier
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
145918
Points
158
Maybe you have an Ezgo cart? Black is negative, white is positive, and the small red wire is connected to the white inside the charger receptacle.
Cart wont move just hums was working ? 85 Ezgo 36 volt
If all wiring is factory then check batteries under load. If all good then test motor. With rear wheels off the ground, disconnect the main pos and neg wires from the batteries. Then disconnect the four wires from the motor. You can use a voltmeter to measure the value of the two coils of the motor. Measure between A1 and A2 then S1 and S2 ( sometimes F1 and F2) Should get 1 or 2 ohms. If that good then jumper A1 to F1, connect A2 to 12 volts and F2 to 12 volts, one neg and the other pos. You will get a spark but the motor should start turning if good.
Jul 26, 2017 • Golf
36V club car. New batteries, new controller, new solonoid, new micro switchs, new cables. It will not make a sound and it will not go. What is wrong?
Verify that all battery cables are wired correctly. Should be in series-- neg to pos , neg to pos etc. Then measure total voltage at the main positive and negative battery posts, should be close to 36 volts. If we are good there then measure the voltage at the small posts of the solenoid when the f/r switch is in either position, the key switch is on and the pedal is pressed. I would do this only if the rear wheels are off the ground. Lets say that you do measure 36 volts there, that would mean the solenoid is probably bad.
Now lets say you don't measure 36 volts. Normally there is a small red wire connected to the main positive battery wire at the charger receptacle, it feeds the key switch, key switch comes back and feeds the micro switch on the back of the f/r switch, then to the positive side of solenoid. So connect black voltmeter lead to main negative and with the red lead measure voltage at solenoid. If no voltage keep working back until you find the trouble.
Assuming you have good voltage on positive side, now we check negative side. You probably have a fan shaped black plastic object mounted on the frame under the seat. It's named V-Glide. When you step on accelerator pedal a micro switch in the v-glide closes and provides negative to the solenoid. I hope this helps.
Jun 23, 2017 • Golf
Wiring a DVC 10 inch sub to 2ohms
RED IS USUALLY POSITIVE
RED-WHITE IS MORE THAN LIKELY NEGATIVE
TO CHECK SPEAKER POLARITY:
1. HOOK LEADS UP AS I DESCRIBED
2.TAKE A AAA,AA,C,OR D BATTERY
3.CONNECT POSITIVE SIDE TO POS ON BATTERY...NEGATIVE TO NEG END......
4. IF SPEAKER "CONE" PUFFS OUTWARD..POLARITY IS CORRECT. IF IT PULLS INWARD..POLARITY IS REVERSED
Polarity on charger plug
white is positive and black is negative, you can also verify this by connecting it up to a multimeter if you hook the white wire up to the red lead of the multimeter and the black up to the black lead it should show a positive voltage, but if you hook the white wire up to the black lead and the black wire up to the red lead it should show negative voltage
Jul 22, 2012 • Toys
2helpful
Troy bilt pony will not start. replaced 20 amp fuse and battery
OK -- Here's what to do:
TROY-BILT PONY LT CRANKING CIRCUIT TROUBLESHOOTING
NOTE 1: The following tests are to be made with the parking brake applied and the PTO disengaged unless otherwise specified.
NOTE 2: These tests need only be made until the cause of the problem is located. The entire process need not be completed if the problem has been resolved.
NOTE 3: Refer to the wiring diagram below for understanding of all tersts.
NOTE 4: Wiring Diagram references to Key switch A1 and L terminals refer to the same terminal.
1. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the battery positive terminal. The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 2.
b. If YES, go to Step 3.
2. Connect a DC voltemeter directly across the battery. The voltmeter should read at least 12.6 VDC.
a. If NO, charge or replace the battery.
b. If YES, check and repair/replace the following items as required, then repeat Step 2 test. If YES on retest, go to Step 3.
-- battery negative cable condition
-- battery negative cable connections at the battery
-- battery negative cable connections at the tractor frame
3. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key swttch "B" terminal (Circuit #97 - red/white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 4.
b. If YES, go to Step 8.
4. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay BAT terminal (Circuit #94 - heavy red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 4 test. If YES on retest, go to Step 5.
-- battery positive cable condition
-- battery positive cable connections at the battery
-- battery positive cable connection at the starter relay
b. If YES, go to Step 5.
5. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder BAT terminal (Circuit #92 - red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 5 test. If YES on retest, go to Step 6.
-- Circuit 92 wire condition
-- Circuit 92 wire connection at the starter relay
-- Circuit 92 wire connection at the fuse holder
b. If YES, go to Step 6.
6. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder protected circuit terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 6 test. If YES on retest, go to Step 7.
-- 20A fuse condition
-- fuse holder condition
-- fuse holder wire connections
b. If YES, go to Step 7.
7. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "B" terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 7 test. If YES on retest, go to Step 8.
-- Circuit 97 wire condition
-- Circuit 97 connection at fuse holdser
-- Circuit 97 connection at key switch
8. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "S" terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 8 test. If YES on retest, go to Step 9.
-- key switch assembly
b. If YES, go to Step 9.
9. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #80 terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 9 test. If YES on retest, go to Step 10.
-- Circuit 80 wire condition
-- Circuit 80 connection at key switch
-- Circuit 80 connection at parking brake switch
b. If YES, go to Step 10.
10. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at
least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 10 test. If YES on retest, go to Step 11.
-- parking brake switch assembly mounting and adjustment
-- parking brake switch assembly condition
b. If YES, go to Step 11.
11. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 12.
-- Circuit 70 wire condition
-- Circuit 70 connection at parking brake switch
-- Circuit 70 connection at PTO switch
b. If YES, go to Step 12.
12. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 12 test. If YES on retest, go to Step 13.
-- PTO switch assembly mounting and adjustment
-- PTO switch assembly condition
b. If YES, go to Step 13.
13. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least
+12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 14.
-- Circuit 60 wire condition
-- Circuit 60 connection at PTO switch
-- Circuit 60 connection at starter relay
b. If YES, go to Step 14.
14. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay MOT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, did the relay make a single heavy "click" noise?
1. if YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
2. If NO, connect a DC voltmeter DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter relay frame. With the key held in the START position, the voltmeter should read a maximum of +0.1 VDC.
a. If YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
b. If NO, check and repair/replace the following items as required, then repeat Step 14 test. If YES on retest, go to Step 15.
-- starter relay mounting
b. If YES, go to Step 15.
15. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter motor BAT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 15 test. If YES on retest, but the starter motor does not engage, go to Step 16.
-- Circuit 93 cable condition
-- Circuit 93 cable connection at starter relay
-- Circuit 93 cable connection at starter motor
b. If YES, but the starter motor does not engage, go to Step 16.
16. Connect a DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter motor frame . With the key held in the START position, the voltmeter should read a maximum of +0.2 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 16 test. If YES on retest, but the starter motor does not engage, go to Step 16b.
-- starter motor mounting to engine
-- engine mounting to tractor frame
b. If YES, but the starter motor does not engage, replace the starter motor.
REFERENCE PART NUMBERS PER WIRING DIAGRAM:
Note that your specific tractor may use differnt part numbers. You can obtain a Parts List specific to your tractor online, at no charge, from Troy-Bilt at www.troybilt.com -- your full model number and serial number are required.
Key Switch 725-04228 (common alternatives are 925-04227B & 925-04659)Parking Brake Switch 725-1657A (common alternative is 725-04363)
PTO Switch 725-1657A (common alternative is 725-04363)
Starter Relay 725-04439
Also note that the starter motor is an engine manufacturer supplied part.
Jul 19, 2012 • Troy Garden
8helpful
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
8helpful
2answers
Ez Go 28115-G01 battery charger does not work.
I have an EZGO powerwise 36V charger, model 28115-GO3 that was installed onboard a cart. I want to use this charger for another cart, but the charger has 3 wires out. Why 3 wires? One is +, the other -. what do I do with the third wire? The wires are red, black and yellow; two odf the wires are 10-12 gauge, the other is around 16 gauge.
22helpful
2answers
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
[email protected]
Top Golf Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
