Dryers Logo
R
Rita Baty Posted on Sep 03, 2015
What does a LOC code mean? - Kenmore Dryers
DLynn
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Oct 03, 2015
DLynn
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
1086
Points
7
Loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
How do i remove the loc code
I appreciate your post, friend!
Based off the information you have provided you are receiving a "LOC" code on your Frigidaire washer. "LOC" typically means that your control lock feature is on to remove the lock feature you need to hold down the options and select buttons for ten seconds. I hope this is helpful. -Matt
1helpful
2answers
ERROR CODE LOC
I'm not sure what just happened here-I posted and my answer went away! Push and hold temp button for 3 seconds and LOC should clear-if you want to lock controls again repeat-cheers Denny
1helpful
Frigidaire affinity dryer loc
LOC is a generic lock code meaning the door was either locked manually or accidentally. Also LOC will lock the control panel and can be manually locked as well. Try to reset the unit for about 10-15 minutes and retry.
20helpful
I just bought a Tasco Digital Trail Camera - 119223C . During the setup my camera display also shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does...
I just bought,last August, a Tasco Digital Trail Camera - 119223C . Took pictures until Jaunary 2011, my camera display shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does anyone know what 'Loc' means? I tried to reformat card, I also so not get a Y/N option for formatting. I bought a new card and changed batteries. no change!
1helpful
2answers
After reconnecting battery radio will not work. LOC appears on screen. power switch has no effect . how do i fix?
Hello.... LOC means that a customer code has been stored into the radio for security reasons. At this point the only code that can be retrieved is the backup code. This code can be retrieved by the dealer. From this code they can get the customer code. If this is not a option may I recommend getting a new radio....
Good Luck
6helpful
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
MY WASHING MACHINE THEY DONT START WHEN I PUSH START IT SHOW UP THE WORDS ERR AND LOC
1helpful
417.44092500 front load washer I get a LOC err,
10helpful
Error code LOC
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
