Question about Leisure GRB6CVR Electric Cooker with Ceramic Hob, Regency Red
Main oven not no heat.thought maybe heating element. tried to take element out from inside oven but seem I may need to take back cover off as it seems the two screws on one side come in from there.
Is this correct??is fan motor easy to change??
    Sergeant:
  • 192 Answers
Yes your doing fine, usually heating element are sturdy and seldom busted. try to follow the wiring inside and locate the thermal fuse that is installed inline with the wiring,have it replaced
Posted on Sep 03, 2015
Testimonial: "thx for reply, so with regards to removing back panel on leisure cooker is just a case of removing all screws in view and slide it off??"
  • Anonymous Sep 03, 2015
  • mj mj Sep 04, 2015
    correct
SOURCE:
Is it easy to replace the Air conditioner fan?
Easy for me, yes. Easy for all, No. If you get the factory part and pay attention the toughest thing is likely getting the blade off without damaging. If you get an aftermarket motor your wire colors change and capacitor size likely does as well. You will then need some experience or know how of what you are doing. Good Luck, buy the motor from the factory if doing yourself.
Sep 29, 2018 | Heating & Cooling
Where is the heater fan relay located 03 chevy venture
It's part of the blower motor resistor assembly . right below the blower motor under right side of dash
Apr 21, 2017 | Cars & Trucks
What does the error message C5351 mean on a Konica Minolta Bizhub 200?
Fault Code
C5351
Description
Power Supply Cooling Fan Motor Failure
- The Power Supply Cooling Fan Motor Lock signal remains set to H for a set period of time while the Power Supply Cooling Fan Motor is turning.
- The Power Supply Cooling Fan Motor Lock signal remains set to L for a set period of time while the Power Supply Cooling Fan Motor remains stopped.
Remedy
1 Check the M4 connectors for proper connection, and correct as necessary. 2 Check the fan for possible overload, and correct as necessary. 3 M4 operation check PWB-A PJ33A-1 (REM) D-5 4 Change PU1.
Oct 28, 2016 | Minolta bizhub 200 All-In-One Printer
Erro 2351 da bizhub 164
C2351Suction fan motor malfunction
- The fan lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary.1 Check the connector between FM5-relay CN13-PRCB CN14 for proper connection and correct as necessary. 2 Check the fan for possible overload and correct as necessary. 3 FM5 operation check. 4 Change PRCB.
164
http://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20164&code=C2351
Sep 11, 2016 | Konica Minolta bizhub Office Equipment &...
1995 oldsmobile cooling fan don't work
change fan motor put 1 on my buick for like 25.00 its a cheap and easy fix just unbolt whole fan pull out and unbolt motor its only 4 screws vry easy fix..
Sep 29, 2013 | Worldwide 1995 Oldsmobile 88 Royale LSS...
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
Car went over temp after about 30 minutes of driving. What could this be?
check for correct fluid level first of all in the radiator,, if the fluid level is fine, you may have a stuck thermostat,, or a fan relay thats not turning the fan on at the desired temp, , start the vehicle and look for a couple of things,, 1 remove the radiator cap prior to starting the motor, ( make sure before you do this that the motor has cooled down) let the motor run so it will warm up,, 2 things to look for,, fluid movement in the radiator once it heats up,, you can look into the radiator cap opening to see this happen, and 2 watch for the fan to come on, If you have ac ,,and a single motor,, leave the ac off, if you have 2 fans on the vehicle, turn the ac on , check to see if that fan started, if so turn that one off , if the fan comes on once heated enough,, the fans are ok, if you see movement in the fluids in the radiator, then the thermostat should be ok, They are cheap and easy to change, so if your not sure, Just replace that part
Aug 26, 2011 | 2002 Pontiac Grand Prix
I get error code c-0046 and now machine will not work. What do I do?
C0046: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Suction Fan Motor (M12) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the connector of motor for proper connection
necessary.
M12 operation check PWB-MC PJ18MC-9 (LOCK)
PWB-MC PJ18MC-7 (REM)
6-P
4 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
necessary.
3 M9 operation check PU1 PJ17PU1-5 (LOCK) 2-K
4 Change PU-1 —
Jun 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Auto Repair: Fan switch or blower, how do I determine which is bad?
there is a thing called a blower motor resistor that controls the fan on cars these days. they are usually in the air box. check with a dealer for your car. its easy to change.
Oct 26, 2008 | 1998 Acura Integra Type R
2005 trailblazer fan motor vibrates whole dash
It is very likely that there is something in the squirrel cage fan blower wheel. It is fairly easy to pull it out and check.
Oct 15, 2008 | 2005 Chevrolet Trailblazer Ext
Leisure GRB6CVR Electric Cooker with Ceramic Hob, Regency Red Logo
119 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
