Samsung PN50C550 50 in. TV Logo
L
Larry B Posted on Sep 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
TV picture was working fine, shipped from Atlanta to Houston. Worked in Houston for about 30 min, and turned off. Red power light will glow steady until power on, then flashes a few times, and then goes dark. Audio on set stopped working prior to shipping. TV stopped responding to remote too. Remote works other Samsund TVs fine. Which boards do I need replace - main, power, X-Y, power button/sensor? Thanks
Coffee Tech
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Samsung Expert 158 Answers
  • Posted on Sep 03, 2015
Coffee Tech
Samsung Expert
Level 2:
New Friend:
Cheetah:
Answers
158
Questions
0
Helped
2831427
Points
503
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Samsung un60fh6200fxza will not show picture but has audio
The board that you replaced is responsible for digitizing all of the data so that it appears on screen. But you do see a picture with the flashlight - The inverter board is responsible for lighting up the backlighting so you can see the image. I would go for that based on what you have noticed.
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
2helpful
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
2answers
The audio on my vizio tv isn't working
Replace the main board. That board controls all the symptoms you're having. You can get the Vizo Main Board 3642-0182-0150 thats the board for your model from www.tvcircuitboards.com it has a 6 month warranty
The remote for my samsung ht-tx72 doesn't work even though the tv and dvd reciever lights on the remote work. It doesn't turn on my home theater system. Do I need to reprogram it?
Possibly. Maybe it's malfunctioning.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
2helpful
2answers
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
hi,
Need the model number of the samsung Home home theatre system to give to correct code.
OK
I can't get my DVD V5500 to work. I can't get any of the function buttons to work on the unit and I can't get the remote to work either, the menu doesn' even come up when I press the...
Possible that the processor is not working. So check on the +5 voltage to the processor IC , if this is absent then power supply is faulty.
If not the mother board can be faulty. Try and see if the board can be switched and confirmed.
My remote will not turn the tv on it work for about a week. I have replaced the batteries numerous times with no help
Can another remote turn on and off the TV? Do the buttons on the TV itself work (assuming a front panel lock isn't engaged)? Is this the original remote for the TV or a universal remote?
The possibilities: 1) The remote has failed. If you have a digital camera, take a picture of the IR side of the remote when someone presses the buttons. When you review the picture, you should see a bright spot in the picture. This indicates the remote is at least sending a signal. Sometimes the buttons will fail to make contact with the circuitry of the remote (due to wear). Other times the IR transmitter fails (the suspect if there is no light in the pictures from multiple button presses of the less used buttons). It's cheaper to replace the remote than it is to repair it.
2) The remote has lost the code for the TV. If you have a universal remote, try reprogramming it. (Cable or Satellite controllers count in this group).
3) The IR receiver on the TV has failed (if the buttons on the TV work) or the entire board has failed. You can get replacements for these at some sites. Try shopjimmy.com (minimally used parts) or partstore.com. You will need to open the TV and get the part number for your individual model for best results.
4) The TV won't turn on due to power supply problems.
If you need a replacement remote, a universal remote should work but the low end ones may not access all of the features of the original. Check for buttons that match features like Menu and Source (Input) if your TV doesn't have equivalent buttons on the TV itself. The remotes that are programmed via a USB connection with a computer are the easiest universal remotes to set up. If you want the original remote (or a close substitute that will perform all of the original features), first check if a parts store exists for your TV manufacturer (Samsung for example). Next try remotes.com and search for the TV model (leave out the manufacturer).
I hope this helps.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
