Well.. if the screen just blurred out, the phone is not a very good phone. but if you dropped it and it blurred out then there is no way to make the screen come back to normal.. i had a phone do that once.. it really sucked hahah.
what problem do you face??? how many times have you tried?? if you have tries left then make a try with Theunlockspot and get unlock code along with instructions and follow the steps and unlock your Motorola Blur..
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
To Hard Reset the Motorola BLUR MB300 quite differs from other Motorola ANDROID phones.
Do back up all your data stored on your device before doing this procedure, this process will delete all the data on the phone but does not delete the data stored on the microSD memory card.
To hard reset Motorola BLUR MB300 1. Power off phone. 2. Hold camera button and power on phone at the same time. 3. Release the camera button when prompted to. 4. You will see a message screen telling you to press the up or down volume button 5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed') 6. When triangle and phone screen appears 7. Press on the screen just above the back key 8. You will now see the "Motorola system recovery" menu At this point you will have three choices:
1. reboot system now [Menu+Back] 2. apply ssdcrad:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W] You can simply tap an item to select it.
At the bottom of the screen you can select OK to apply your choice from the menu.
There is also an opportunity to select Hide on the bottom left, I don't know what that does (I tried it and nothing happened).
Selecting Wipe data/factory reset and tapping Ok and the screen changes to a box and a phone (Get it - out of the box) and you see what is happening on the phone. pick 2 -- Wiping data... Formatting DATA:... Formatting CACHE:... Data Wipe Complete.
Press Menu+Back to reboot
pressing Menu+Back did nothing for me so I tapped 'reboot system now' on the menu and Ok.
The phone restart then will restore back to its factory default state.
yeah can someone please answer this question my brother got me a phone yesterday its a M blur touch screen and it wont charge and wen i try to turn it on it just shows the M but doesnt load and sometimes it just turns off but sometimes it goes to my screen n its out of battery and it says please plug in charger and i hook up the charger and it doesnt charge!!! please help me
Try doing cold boot - unlatch the battery, hold down trigger then the power button release the trigger while still holding the power button until screen resets. release the power button and wait for a screen prompt to latch the battery again. If still fails to boot you may need to do a OS update via SD card as the OS may be corrupt. BTW doing a OS update will wipe everything!
