SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V. First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2. Also check the connections and continuity for the heater element.
SOURCE: GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
http://www.repairclinic.com/0088_8_1.asp
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
SOURCE: AEG 59800 dryer is not drying, it runs the full
If the clothes going in don't appear wetter than normal, then it's probably lack of airflow.
Check your dryer venting.. especially directly behind the machine. Pull the machine out and disconnect the 4" duct from the back of the machine and visually check for blockage both in the machine and in the duct work. Use a vacuum hose to remove any debris.
You can also start the machine while it's disconnected from the duct, momentarily to check for proper airflow.
Best of success!
Testimonial: "Spot on, its a condenser dryer and the intake filter was blocked. Thank you so much"
