Casio fx-300ES Plus Scientific Calculator Logo
A
Anonymous Posted on Sep 03, 2015
Not giving proper awnsers for square root questions
Whenever I enter th calculation (im not sure how to enter mathamatic signs) square root of 8.32-4 (outside) -3 to the power of 2, it gives me the awnser -45+6 square root of 3 all over 5. What can I do to make it give me an exact number and decials rather than this? Also this might be related to this but whenever i enter something like the square root of 13 it gives me an awnser "the square root of 13"
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on May 22, 2018
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671816
Points
21595
Contrary to what you believe, results with square roots are exact. Decimals are approximate.
Press the SD key to convert from standard to decimal representation.
3 Related Answers
A
Anonymous
  • Posted on Sep 10, 2008
SOURCE: Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
k24674
  • 8093 Answers
  • Posted on Sep 06, 2009
SOURCE: square root of 0.5
Hello
If you want a number in decimal form all you have to do is press [S<-->D].
Hope it helps
  • 102366 Answers
  • Posted on Feb 03, 2015
SOURCE: How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
2answers
What are the keys to enter to calculate square root
The square root is the second function of the "3" key. To calculate the square root of 2, press 2 2ndF =
How to calculate the n root of x on BA 2 Plus?
Use the universal power key [^] with a fractionary exponent.
Fifth root of a number a is entered as a^(1/5).
n root of number a is entered as a^(1/n)
Careful: if the radicand (a) is negative, and the index of the root is even (2, 4, 6, ) the root is complex and the calculator will give you an error. If the index n is odd you can calculate the n-th root regardless of the sign of the radicand.
2^(1/5)=1.148698355
How do I find the square root of a number? and how do I enter scientific equations?
For square roots, use the square root key just to the left of the divide key. For example, 4 square-root = will give you 2.
The calculator doesn't have any way to store equations, scientific or otherwise. If you mean scientific notation, use the EE key just above the 7 key to enter exponents. For example, to enter 1.23x10^6, press 1 . 2 3 EE 6. For negative exponents, make sure to use the +- key to the right of the decimal point instead of the - key.
4helpful
2answers
I need to know how to enter anything above cube root into my TI-83.
  1. Use the universal power key marked with [^].
  2. To avoid problems if the exponent is an expression, enclose it in parentheses.
  3. To enter any power type number^(exponent)
  4. If exponent is negative use the (-) change sign key next to the dot, below the 3 key.
  5. To calculate the roots (cubic, fourth, fifth, etc.) roots use the fact that a root of n-th order can be represented as ^(1/n)
  6. Ex: cube root of 27: 27^(1/3); square root of 64 : 64^(1/2) or 64^(0.5)
1helpful
2answers
How do you tak the square root of 64 or the 4 root of any other #
Hi shiny_diamon
Here is a picture of the powers and root functions of your calculator.
1.To calculate the cubic root of a number you use the key combination shown on line 5
Ex: Cubic root of 27
27 [2nd] [3 root x] [EXE]; Should get 3
2. You can use the general root key on line 7 [2nd][x Root y]
Ex: Cubic root of 125
125 [2nd][ x Root y] 3 [EXE] Should get 5
(-125) [2nd][x Root y] 3 [EXE]; Should get -5
3. You can also yse the general power key on line 6: [Y to x], but the degree of the root is entered as a fraction 1/3
Ex: cubic root of -125.
(-125) [Y to x]( 1/3) [EXE]; You should get -5
4. The [Y to x[ key is the one you use to obtain all other roots fourth, fift, tenth, n-th.
Ex: Fourth root of 256
256 [Y to x] (1/4) [EXE]: You should get 4
5. To extract the squqre root of a number you can use the key on the 3rd line [root x] or the general power key on line 6 with exponent 1/2
Exemple square root of 256
256 [Root x] [EXE] should give you 16
256 [Y to x] (1/2) [EXE] should give you 16 also
Hope that helps.
1helpful
2answers
Need to know how to do squre roots step-by-step
type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
4helpful
How do you use x of square root on a ti-30x
If you can't find the square root sign you could enter it like:
4^(1/2)=2 and 16^(1/2)=4 just what #your look for the square root of just take to the ^(1/2)
I'd like to give the key reference for the square root sign but, I loan my calculator to a student
1helpful
I need to use the square root sign but I need to square root with 3, 4, and so on.
If you would like to a root other than a square root, first enter the root value (3, 4, 5, etc.) then press MATH. Then Press 5 and enter the value you want to take that root of. Press ENTER.
5helpful
2answers
How do you use the imaginary number with the TI-84 calculator?
If you want the answer in rectangular form, set MODE a+bi and tap ENTER and QUIT. Tap square root sign, tap (-)4 and close the parenthesis and tap ENTER. The answer is shown as 2i.
If you want the answer in polar form, set MODE to re^xi and and DEGREE. Tap ENTER and QUIT. Tap the square root sign, tap (-)4, close the parenthesis, and tap ENTER. The answer shown is 2e^90i. (2 at ninety degrees). If you selected RADIAN mode, the answer would be 2e^1.57i (2 at 1.57 radians; or 2 at pi/2 radians)
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
