With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
Hi, I have a Gateway PC DX4840-11e with Window 7 system.
It was working ok, until free months again, when Windows start update to 10.
The system is still Window 7, the problem is that when I use it, the computer without reason/ warning, the computer get stuck and the monitor becomes black. However, the computer is still on. The computer' power LED is still on, the fan is still working, but everything just stuck and black.
So, I try to force turn off the computer; then, try to turn on again. It is not Boot. The power on, but it is stuck in there, no Boot, then of course not going to the Window.
Wait for few minutes, I turn on again. Then, this time it is working right.
Until... It happen again.
1. I changed a new Video card.
2. I did soft spy hunt.
3. I did change the CPU' heat sink grease
After I did those steps, the computer will working right for few days, few week; then stuck again.
Please help! Thanks!!
May 27, 2018 - my konka smart tv is stuck on smart tv loading doesnt go further - Televison & Video. ... check the site linked here. Pull up older posts. ... My TV Konka LED TV KDL55XS712AN is not starting and saying: LOADING... Corrupted ...
Sep 2, 2016 - Konka LED TV KDL55S712AN has refused to start and is staying in the screen on" Smart TV loading..." ... Then on the actual TV, hold the power button for 60 seconds then release. Then wait 10 minutes, connect the power again to the TV, turn it on and tell me please if it is now operating correctly.
1 answer
Restart The Device. This is the first step in troubleshooting an Android device that won't boot past the startup screen. If this has not been done, it ...
Try removing the battery and then holding down the power button for a few minutes to discharge the cache. Reinstall the battery, and without starting the phone, plug it in to charge. If this doesn't work you will have to do a hard reset.
INSTALLER FAILURE AND NO WINDOWS VERSON TOLD AT ALL.
USELESS TO GUESS.
AT END OF PHASE ONE INSTALL AND IT WARNS REBOOTING
REMOVE ALL INSTALL MEDIA NOW, OR IT WILL GO TO LOGGERHEADS BOOT LOOPING PHASE1 ENDLESS.
OR have boot order right.
HDD0 first and below 2nd.
USB or DVD at the install media is.
ordered correct in BIOS and use boot on the fly hot key
of most PCs, that have that, and force boot USB/DVD
and when phase 1 ends the 2nd boot lands on HDD.
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args
Display this message (same as -?)
-i
Display GUI interface, must be the first option
-l
Log off (cannot be used with -m option)
-s
Shutdown the computer
-r
Shutdown and restart the computer
-a
Abort a system shutdown
-m \\computername
Remote computer to shutdown/restart/abort
-t xx
Set timeout for shutdown to xx seconds
-c "comment"
Shutdown comment (maximum of 127 characters)
-f
Forces running applications to close without warning
-d [u] [p]:xx:yy
The reason code for the shutdown u is the user code p is a planned shutdown code xx is the major reason code (positive integer less than 256) yy is the minor reason code (positive integer less than 65536) Do reply me if it sort out your prob
Ok, first off when you turn off the computer without shutting down, windws does not get enough time to wirte necessary data to the disc, this does not always cause aproblem because sometimes there are unpredictable events such as power failure..
You might need to format your hardrive to fix this problem
To do this boot with the windows cd, it will say press any key to boot from disc. (YOU MIGHT NEED TO SET YOUR BOOT DEVICE IN THE BIOS(SETUP))
anyway fisrt off try a fresh install, leaving your current file system intact. Id that works then you will still have all your data on your disc, If not then you need to do a complete format.. Good Luck
