Acer Aspire 5050-3242 Notebook Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my laptop the power lights come on..but the screen never turns on? and an orange light comes on in the front?
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Jul 12, 2009
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
26453
Points
285
Your LCD might be out, try it with an external monitor, if it still doesn't work contact your computer manfacturer to do a service request or go to your local computer repair shop and have them service it. Hope this helps!
Roshan Rijal
Level 2:
Sergeant:
  • Expert 361 Answers
Roshan Rijal
Expert
Level 2:
Sergeant:
Answers
361
Questions
Helped
158815
Points
942
It is problem of monitor. change another monitor to check thanks
Anonymous
Level 2:
Sergeant:
  • Expert 322 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
322
Questions
0
Helped
86537
Points
960
Try refomatting it.
Dell wont turn on
i have a Dell ultrasharp u2410. I turn the screen on and you can see the blue light ascending, but hen it stops and only orange light comes on and nothing, I think it says in power save mode.
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Rplaced power unit now the monitor will not come up with anything on it. Orange light blinking on front of cpu.
Make sure your monitor is connected to the proper video connection- that is if you have a video card in your machine and a video connection on your motherboard. If you connected to the motherboard and you have a video card -your screen will show nothing even though you are powered up. Dont know your situation, but just checking. Ive seen others do this.
Char S.
2answers
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
2answers
Acer aspire 9300 laptop
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
I have a laptop and there seems to be a light currently flashing orange along the front. Ive searched everywhere to find out whats happened but the laptop won't switch on at all. Its a toshiba Prestege...
The flashing light on the front of your laptop is a low battery warning. There probably isn't enough power in the battery to turn on the laptop. You need to plug in the ac power adaptor and let the battery charge until the battery light turns from 'orange', to 'green'.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
