I am using windows 7, but any other operating system should be either the same or very similar. Start by going into control panel. Then region and language. A windows should pop up. Click on the Keyboard and language tab, and click on the change keyboard button. There should be a box with all of the installed keyboard languages. If US is installed, then click on the rest, and remove them. If not, click on add, install US, and then once you do that, delete the rest of them. Click ok, and you should be all set. Really hopes this helps. Good luck.
you need to change the keyboard lay out.
Windows 7 or Windows Vista
Click Start Collapse this imageExpand this image, type intl.cpl in the Start Search box, and then press ENTER.
On the Keyboards and Language tab, click Change keyboards.
Click Add.
Expand the language that you want. For example, expand French (Canada).
Expand Keyboard list, click to select the English (UnitedS tates) check box, and then click OK.
In the options, click View Layout to compare the layout with the actual keyboard.
In the Default input language list, click English (United Kingdom) - English (United States), and then click OK two times.
In the Regional and Language Options dialog box, click OK.
Note The Language
bar appears on the taskbar. When you rest the mouse pointer over this
bar, a tooltip appears that describes the active keyboard layout.
Click the Language bar, and then click English (United States)
Windows XP
Click Start , type intl.cpl in the Run box, and then press ENTER.
On the Languages tab, click Details.
Under Installed services, click Add.
In the Input language list, select the language that you want. For example, select French (Canada) .
In the Keyboard layout/IME list, click English (United States), and then click OK .
In the Select one of the installed input languages to use when you start your computer list, click English (United Kingdom) - English (United States), and then click OK.
Note The Language
