SOURCE: My NordicTrack E5 vi Elliptical is squeaking really bad. How do I fix this problem?
go to :http://www.ehow.com/how_4681374_fix-elliptical-machine.html
God bless you
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
SOURCE: nordictrack cx1055 vibration problems
see the next steps: Lube and use the logically. God bless you
Inspect the leveling feet on the rear stabilizer of the
elliptical. Note if both sides are not flush to the floor. Unplug the
machine if they are not flush to the floor.
SOURCE: NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
SOURCE: nordictrack 1300 elite elliptical manual
go and download the instruction manual and follow the instr.
normally the batteries goes under the display board.
However follow the instr manual
www.fitness.manualsonline.com
God bless you
