Lands Phones Logo
l
lee faa Posted on Sep 01, 2015
How do I change the voicemail to my IP1NA-12TXH phone? its been the same greeting for 7 years and nobody has figured a way to change it
How can i access voicemails on NEC phone system model P4WW-12TXH-B-TEL(BK) please
You model number is the number of the phone that goes with the SL1100 Phone System. It have to be set up in the Management System first to be able to access from the phone. The designation (BK) signifies the phone is Black as opposed to (WT).
The NEC IP4WW-12TXH-B-Tel Phone 1100061 is a phone designed for the SL1100 system. The 1100061 is a 12 button phone featuring a full duplex speakerphone, headset jack, backlit display, and more!
NEC SL1100 Phone IP4WW-12TXH-B-TEL (BK) 1100061 ...
NEC SL1100 Telephone & Voice Mail User Guide
Interconnect Services https://www.interconnectservices.com > 2015/12 PDF TO ACCESS VOICEMAIL. ? From your phone press VM soft key. Follow prompts ... ? From outside the office, dial main number. When the voice mail system answers, ...
2 pages
Missing: bk) ‎' Show results with: bk)
NEC SL1100 Phone System Manual
Rhode Island Telephone https://www.ritelephone.com > uploads > 2019/04 PDF
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
1helpful
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
2helpful
Changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
2answers
I need to know how to use the caller id on the NEC Aspirephone Model IP1NA-12TXH Tel (BK)
i need to know how tosee my call and delete then fron the phone
4helpful
Need to change main greeting and wipe out an old unknown password
Start here for the Auto Attendant greeting. http://dstech1.com/changing-the-greeting-on-voicemail/
Once you figure out what voicemail this is, you will need to go into Voicemail Admin Programming to re-initialize the password for an extension.
20helpful
3answers
Would like to change voicemail message in phone
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 • Cell Phones
2answers
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i have, might help you guys out
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
