I assumed you are talking about your wireless phone.
Are you worried about handset ringing or the incoming call ring?
1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone.
Hope this helps. Best regards.
SOURCE: VOIP will no ring
Just "VOIP Phone" is not enough information to help you. There are many hundreds of different phones, connections, & setups you could have. What type of phone (make, model number)? Is this a VOIP phone connected through a home network, cable modem etc.. for home use? Is it a single line phone connected to a VOIP box connected to your cable modem? Is it a VOIP phone system connected to regular copper phone lines? Are you using a VOIP phone at home connected to a VOIP phone system at work?
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
SOURCE: How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
the ringer is too loud and the beeps from pressing the buttons are too loud.
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
