Sony Ericsson Xperia Arc Logo
N
Nandan Shetty Posted on Sep 01, 2015
How to format phone when it is not turning on or connecting to the laptop ?
3helpful
3answers
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
tip
How to Transfer Files from Cellphone to Laptop and Vice Versa
<span>There are three ways that you can use enable for you to transfer files from your cellphone to your laptop or vice versa.<br /><br /><span style="font-weight: bold;">1. </span> <span style="font-weight: bold;">By using a connectivity cable</span>. <br /><br />It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.<br /><br />A connectivity cable looks like this.<br /><br /><img src="carloadrian_2.jpg" /><br /><span style="font-weight: bold;">2. Bluetooth</span>. <br /><br />Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth. <br /><br /><a href="/../support/t8013435-connect_laptop">CLICK HERE</a><br /><br /><br /><span style="font-weight: bold;">3. Memory Card<br /><br /></span><img src="carloadrian_4.jpg" /><br /> <a><br /></a> <span style="font-style: italic;">SD cards are used in many cell phones</span>.<br /><br /> Many cell phones come with removable memory chips, which can be used to expand the available storage on the cell phone, or to transfer files (such as music and pictures) between the cell phone and other devices. Once you identify the kind of expandable memory in use on your phone, an adapter can usually allow you to connect it to a laptop as if it were a USB drive. <br /><br /><span style="text-decoration: underline;">INSTRUCTIONS</span><br /><br />1. Determine what kind of two-gigabyte memory chip your cell phone uses. You can do this by checking the specifications of your cell phone in the manual or on the manufacturer's website, or by removing the card and examining it. As of April 2010, the most common kind of memory card used in cell phones is the SD format, which comes in standard, mini, and micro sizes. Your phone may also use the Memory Stick Pro or Pro Mini format. The format type will be printed on the side of the card. <br /><br /> 2. Purchase a USB adapter for the card you are using, which is available from many different vendors. If your card is in a mini or micro format, make sure that the adapter comes with a sleeve for the card of your size; this allows you to insert a mini or micro card into the sleeve, and changes the card into a standard size for use with the adapter. <br /><br /> 3. Insert the card into the sleeve, if necessary, then into the adapter. Connect the adapter to a USB port on your laptop. The card will appear on your laptop as if it were a USB drive. When you are finished working with the card on your laptop, you can move it back to your cell phone.<br /><br /><br /> </span>
on Jan 28, 2011 • Cell Phones
3helpful
My fone have virus.how can i remove virus without formatting my fone and memory card.is there an antivirus for LG Cookie KP500? And plz tell me the procedure for formatting my fone,and memorycard.
If you have the pc suite of your phone on your laptop and there you have anti-virus on it then,you can connect the phone to the laptop and scan it
1helpful
How do I upload pics from my cell phone to my laptop
There are three ways that you can use enable for you to transfer pictures from your cellphone to your laptop.
1. By using a connectivity cable. It is a cable which you can buy from any cellphone stores. Just plug the other end to your computer and the other to your cellphone. You can then access the pictures in your cellphone.
2. Bluetooth. Click the link below so that you will be directed to the procedure on you to connect your cellphone to your laptop by using bluetooth.
CLICK HERE
3. Memory Card
SD cards are used in many cell phones.
Here's the instructions on how to do that:
Hope this helps.
Please don't forget to rate this solution. Leave your comments or suggestions on how I can improve my service.
Thanks
4helpful
How to transfer music files
Nokia always support AAC format song. Even others also like MP3,mp4 etc. If you face the problem in normal version then setup your PC suits in your laptop after that connect the mobile and transfer all the song in AAC format in your mobile. Thanks.
8helpful
2answers
How do I format a memory card for a LG Xenon GR500
Go to Top Menu > Settings > More > Connection > USB Connection Select 'Mass Storage'. This enables Windows to see the Micro SD card in your phone as a storage drive and you will no longer get the format message when you plug your phone in to your PC. After this I was able to drop mp3 files into my phone and use them as ring tones.
1helpful
Bluetooth connection problem with P1i
switch off the phone and try again try formatting the phone
Internet connection
After installing your OS install Ethernet adapter.
It's setup comes along with the motherboard cd that is given to u ...when u bought ur laptop.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
