We haven't upgraded to the HD package from Dish Network yet. Would that also cause problems? I know using the TV remote does not offer the correct size. Thank you for your help.
SOURCE: picture display format doen't fit 32'' screen
if you have cable box or a sattelite change the resolution of the STB to 4.3
SOURCE: Bought a new Sanyo tv and have dish network,
You need to call DishNetwork and program the remote. The remote does not know your TV code. Easy fix.
SOURCE: DP46849 has black screen with power light on.
It may be in safety shut down mode due to shorted circuits or power supply failure due to such thing as bad DC filter caps. You will need to do in-depth troubleshooting.
See www.shopjimmy.com if he has the picture of the boards.
Please read my guides also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: Programming my remote control (which is a dish
In order to program the remote to a TV set, hold the clear "TV" button in the upper left hand corner four four seconds or until all four of the mode buttons light. Next press in one of the three digit codes below followed by pound (#) Remote codes: 590, 683, 720, 591, 543, 593, 813, 542, 533, 652, 726, 611, 500, 503, 627, 661, 956, 591, 694, 666, 252 After trying each code press the volume and power buttons, if they control your TV set be sure to press the "SAT" button.
Daniel Busa
DISH Network
Customer Service
