Question about Nordic Track NordicTrack X7i Incline Trainer
Incline not moving
Not calibrating
  • Nordic Track Master
  • 6,694 Answers
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Posted on Aug 31, 2015
SOURCE:
I have a Norditrack X5I NTL15909.0 and the incline stopped working so I did a calibration and it is stuck in calibrate mode.Every time you turn the power on it tries to calibrate up 2" and down 2"?
You need a new incline motor, The incline sensor is bad. One way to test is to pull the black and red off the MCB and applied 120 volts on the black (up) or Red (down) wire and see the incline motor move. If it does then the MCB is bad
Apr 05, 2015 | Exercise & Fitness
Treadmill incline not work
Run please the software calibration for easy diagnostics+and fix it.
God bless you
Jul 06, 2013 | Exercise & Fitness
Kettler atlantis 51L error!!!! what is the solutions?
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Aug 17, 2011 | Exercise & Fitness
The incline on my proform treadmill is not working and now I can't get the treadmill to start, it just keeps inclining up and down
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Jul 09, 2010 | Proform 650 Crosstrainer Treadmill
Icline does not work
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. Remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
When it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) . If you have voltage but the motor won't move, you need to replace the motor.
Jun 13, 2010 | Proform Crosswalk 500 Treadmill
When you turn on treadmill the incline goes all the way up and all the way down. Does nothing else.
First we need to do a calibration follow this procedure
THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad Call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 29, 2010 | Proform 675 E Treadmill
I have a Image 15.5 Treadmill, it turn on, Incline...
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad call icon Fitness @ 800-999-3756, they may have the sensor or they tell you, you need to replace the incline motor
May 21, 2010 | Icon Image 17.5 S Treadmill
When I turn on the treadmill, the incline is stuck @ 12degree and the console beeps and I can not control the treadmill at all. What do I need to do?
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of incline, press the Stop key and then remove the safety key.
  1. If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
  2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
  3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
May 15, 2010 | Epic View 550 Treadmill
The treadmill will not incline
Try calibrating the unit first, if this does not work than check below:
1. If the incline moves but you will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad and needs to be replaced.
2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. Remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4. If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced.
Feb 20, 2010 | Exercise & Fitness
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track NordicTrack X7i Incline Trainer Logo
462 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
