LE error - drum will not spin. Made noise when in wash cycle, and locked up prior to spinning.
You sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
