Question about Nostalgia Electrics CCP610 Popcorn Maker
Need new kettle. Where can I get one ? - Nostalgia Electrics CCP610 Popcorn Maker
I need a spout filter, part # 31036 for my express kettle MEK 17W
  1. New: Melitta Kettle Parts - buycheapr.com‎
    Admelitta-kettle-parts.buycheapr.com/‎Melitta coffee maker parts: BuyCheapr.com
  2. Melitta Kettle Parts - bizrate.com‎
    Adwww.bizrate.com/Melitta+Kettle+PartsVacuums
  3. Microwave Ovens
  4. Coffee Makers
  5. Heaters
  6. Melitta Cordless Kettle - Amazon.com‎
    Adwww.amazon.com/kitchen‎rating for amazon.com
    Up to 50% off Melitta cordless kettle Free Shipping on Qualified Orders.
    Ratings:Website 10/10 - Shipping 10/10 - Selection 10/10
Search Results
    Need replacement filter for Melitta Express Cordless Kettle ...
    www.fixya.com/support/t6685355-need_replacement_filter_melitta
    Nov 3, 2010 - Need replacement filter for Melitta Express Cordless Kettle Model MEK17W - Salton Melitta MEK17W Electric Kettle question. ... Question about SaltonMelitta MEK17W Electric Kettle ... Video; Photos; Link; Replacement Parts.
Jan 06, 2016 | Kitchen Appliances - Others
I plugged my kettle into a 240v by mistake. The kettle won't work now, how do I replace the spark plug or fix this issue?
No Spark Plug in a kettle :>)
If the kettle was 12 volt battery (as you posted in 'Cars and Trucks') operated in a vehicle, or 100 volts in a mains outlet and you gave it 240 volts, the kettle is history. You need a new one.
Nov 04, 2015 | Cars & Trucks
No longer turns itself off when boiling
modern kettle are made to be disposable items. You will need to buy a new one.
Nov 04, 2015 | Kitchen Appliances - Others
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
Apr 09, 2015 | Kitchen Appliances - Others
Kettle won't work after switching on with no water inside
It depends on how long you switched on.
*check to make sure that the switch is transmitting electricity if not...
*from my experience with kettles you will need a new element*Depending on the kind of kettle you are using check the power cable and the base of the kettle to make that there is contact between the kettle and the power cable.
Apr 03, 2013 | Kitchen Appliances - Others
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
Leaking jug
A common cause is the calcium, or some other minerals in the water eventually ate through the bottom of the tank. You will need a new tank, or better... A new kettle.
Jerry G.
May 07, 2012 | Russell Hobbs RHOK3123 Cordless Electric...
I need a new kettle where do I go get one?
you can order a new kettle online at www.ebay.com u have great offers there.
Jun 09, 2009 | Bond Helman Old-Fashioned Movie Time...
Where can I get a filter for a Rowenta filtermatic kettle?
There should be a manual with your unit, if not contactthe company by internet, they should have an ordering section.
Jan 05, 2009 | Rowenta KETTLE Electric Kettle
Nostalgia Electrics CCP610 Popcorn Maker Logo
271 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Anthony Ward
Anthony Ward
Sheldon Dedek
Gil Shultz
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
