Vehicle Parts & Accessories Logo
erin fryou Posted on Aug 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you bypass an azimuth error code on a sitex t180 radar?
John Nolan
Level 2:
Sergeant:
  • Expert 347 Answers
  • Posted on Mar 09, 2016
John  Nolan
Expert
Level 2:
Sergeant:
Answers
347
Questions
0
Helped
73469
Points
601
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
  1. Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
  2. Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
  3. Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
  4. Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
  5. Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
  6. Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
6answers
Garmin radar error code 8
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
My radar is smr3600 have fault azimuth whats prblem
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
It is showing Error Code "A"
"A" is not an error code. It means "all bogeys" and should be working fine
Falta de catalogo
interfase del sitex explorer plus
Hi,I need a replacement battery pack for my Sitex handheld VHF HH-250.Thanks Original 8N-600
What you need is at the VERY least is a Ni-Cd battery pack with 600mA/hr rating. We have an HH-300, with a configuration of 4AAx2.
Interstate Batteries has the BEST price I could find, although when we bought the HH-300, I sent it to SiTex for a new battery AND a tune-up which cost around $100.
Here's the link to the Interstate battery website.
<a href="http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd">http://www.interstatebatteries.com/cs_eStore/Products/RT/PID-NIC0068(Other+Products).aspx?dsNavigation=Ntk%7eSearchGroup%7cSitex+HH%2f-250%7c3%7c%2cNy%7eTrue%2cNtpc%7eDisabled%2cNs%7eproduct+Type%7c101%7c1%7c&Title=9.6V+800mAh+NiCd</a>
Hope this helps.
(EDIT)
Do NOT forget that these radios are wired center pin negative! (Don't ask how I found this out...)
Furuno 1715 Radar - 'NO HEADING PULSE'
More than likely the belt has come off again. This is a common problem with this radar. You'll need a small allen wrench to tighten it up again.
2answers
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
