Question about Electrical Supplies
No AC power when running - Electrical Supplies
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
You need to determine if it is a Brushed or Brushless generator and follow the tests on the link below. (You will locate the brushes on the end of the alternator in a 12o'clock position if they are fitted).
http://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Then contact Generator Guru with the results and they will let you know what needs replacing. This is a free service.
Posted on Sep 25, 2015
    Top Expert:
  • 12,962 Answers
Check for any fuses and/or reset buttons - check manual. If all is copacetic then the issue is with the generator itself.
Posted on Aug 30, 2015
SOURCE:
Toshiba 1905-s301 wont run on just ac power
Check your AC Adapter for voltage output using a multi-meter. If voltage is lower than stated replace Adapter. When replacing adapter verify Amperage is same before purchase.
Dec 18, 2013 | Toshiba Satellite 1905-S301...
I have a Dell Latitude D800. I want to run it on AC power. Do I have to take the battery pack out of it before I ru it on AC power?
Hello Paula, Hi Never remove the battery out when powering with AC, your Dell will get busted, run ac with the battery. The AC power produces a voltage above the normal operating voltage of the Dell, the over voltage is for charging the battery and powering the DELL, if you remove the battery, the over voltage will bust the laptop in seconds. So operate the laptop with AC and battery.
Feb 11, 2011 | Computers & Internet
Runs on battery only wont charge or run on ac power charger working on another laptop fine
Computer power probems are traceable to batteries, ac cables and power outlets. First, the computer batterie should charger fi were situated appropiated in the compartments without ac cables power cord malfuctions.
Jan 28, 2011 | HP Pavilion dv6000z Notebook
Approximately 5 weeks ago I started getting the message when on AC power that the "smart AC adapter is not providing enough power" (something like that anyway!) And even though plugged in would...
first, you need to try to power on your laptop with another battery with the AC adaptor plugged in. if your problem was not solved you need to check the power jack on your mothernorad.
Jan 02, 2011 | HP Compaq 6735s Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
Will not run on AC power or charge battery
If issue occurs with a known good AC adapter then next is replace the motherboard. Around $150 on EBay
Oct 03, 2009 | Dell Latitude D600 Notebook
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
Laptop won't run on ac power and keeps shutting down
Check that the AC power works, go to a repair shop and test a different one or have voltages checked with a multimeter.
If the AC adapter is fine, then it is usuall because AC socket solder joints on laptop are broken. In this case , it is a delicate repair, and must be done by an expert repairman.
Dec 13, 2008 | Toshiba (K000006610) for Satellite P25...
Electrical Supplies Logo
87 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
