Akai LCT2060 Television Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Television will not turn on. - Akai LCT2060 Television
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Aug 11, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
12275
Points
105
Go to service station
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • 0helpful
    Sony LCD turns off 34 flash turn on 30sec repeats ...
    The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
    • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
    • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
    NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
    If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    lno2()
    Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
    TV Doesn't Turn On
    • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
      If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
      If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
      Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
    TV Turns Off By Itself
    • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
      If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
      Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
    • Blank Screen
    • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
    Won't program to our new TCL television - we have the 222 receiver
    I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
    • Remote: Basic Remote (Television Only)
      1. Turn the Television On.
      2. Press and hold the clear TV button for three seconds until the LED flashes.
      3. Press and release the red TV Power button.
      4. Press and release the Up or Down Arrow on the remote until the television turns off.
      5. After the television turns off, press and release the # button.
      6. Test functionality with the TV.
      7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
    Color recently changed and I cannot get it adjusted properly. Picture goes in and out.
    Please do the following steps:
    2. Please wait approximately 40 seconds for your TV to completely start up.
    3. On the TV remote control, press and hold the UP ARROW button.
    4. While holding the UP ARROW button, press and release the POWER button on the TV set. (The button may be on the front, top or side of the TV.) NOTE: The TV may turn off and then back on.
    5. Release the UP ARROW button.
    If the issue does not resolve, please follow these steps:
    2helpful
    My tv keeps shutting on and off
    You television is having problems with intermittent component failure. The reason the television turns off and on is the protection circuit turns on when it senses high voltage or current level that may damage the internal circuits. The protection circuit turn the television off, the television will stay in this condition until the faulty component or components temporarily stabilize. When this happens the television attempts to turn itself on again. Once the component or components heats up it loses tolerances and again triggers the protection circuit to turn the television off. This is a problem that should be fully tested and evaluated by a certified service center. You can contact RCA customer support at this telephone number 1-877-947-7977 between the hours of 8am-8pm M-F EST and. 10am-7PM S/S EST. You can also contact RCA customer support on line at this web page link http://tv.rca.com/en-us/ContactUs.html I hope this information help you solve your problems with the television. Thank you for using FixYa and have a nice day!
    2answers
    MY sony wega 40 inch won't turn on
    The STANDBY light is flashing on the television and there is no picture or sound. Solution
    sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    3answers
    Sony KDF55WF655
    TURN TIMER OFF OR, The STANDBY light is flashing on the television and there is no picture or sound. Solution
    2answers
    Fix my tv
    COULD BE FANS NOT WORKING. TAKE BACK OFF AND SEE IF TURNING, CLEAN THEM, OR TURN STAND BY MODE OFF OR GO TO SONY.COM, TROUBLESHOOTING OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
    4answers
    Sony kv32fs16 problem
    Top Akai Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
