Http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/TRUE-T-23_iom.pdf. Check out this manual. has instructions.
The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If a colder temperature is desired, turn the temperature control knob toward MAX and allow several hours for temperatures to stabilize between adjustments.
In my experience, the temperature adjustment knob is behind the grill on the side. They put it hidden there because you hardly ever need to touch it. The model number isn't quite right for a Kenmore. It should be 3+5 numbers 123.12345 like this one 253.12502
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
dear sir/madam
i think your freezer,s temperature control device is not working so compressor is working continuously or there can be possible low gas problem so, pleasecontact to maintenance personnel for further action.
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
please find out temperaturecontrol switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
The temperature controls are located at the top front of the refrigerator or freezer compartments. The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm. Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil. NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster. If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls. To turn Off/On: Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool. Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models) The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off. Press the control to On to save energy when the environment is less humid. Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls If you need to adjust the temperature in either the refrigerator or freezer compartment. NOTES: For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature. Except when starting the refrigerator, do not adjust either control more than one setting at a time. Wait 24 hours between adjustments for the temperature to stabilize.
