Cars & Trucks Logo
b
brenda ruffin Posted on Aug 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car not getting gas in line - 2002 Cadillac Escalade Ext
john h
Level 3:
Top Expert:
  • Cadillac Master 29,494 Answers
  • Posted on Aug 28, 2015
john h
Cadillac Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561177
Points
193449
Turn key to on position not start and listen for hum or have someone listen for hum by gas tank fill hum is fuel pump working --no hum check relay -and pump for power and wiring problem -try to start with starter fluid if starts fuel pump problem --- usually shot and needs replacement ---
carla the car guy
Level 2:
Habit-Forming:
New Friend:
  • Expert 47 Answers
carla the car guy
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
47
Questions
Helped
16223
Points
122
Brenda I believe that your fuel pump has gone to be with the car gods. You can check by disconnecting the fuel line AFTER the pump and having someone pump the accelerator if there is no fuel out then congrats - you found it!
A/c system the high side line gets very hot ?
Yes. One line gets hot and the other gets cold. The freon gas carries hot air out of the passenger compartment and expells it from the condenser. The freon gas changes from gas to liquid and back again.
2helpful
Installed new fuel pump because car had old gas in tank. removed tank and completly drained it. replaced tank and installed new fuel pump and fuel filter. put about 6 gallons of gas in car. have tried to...
Okay, you need to make sure the fuel pump is getting power and that you have the lines hooked up correctly. Also, when you replace fuel pumps you need to remove the air cleaner and use starter fluid to get the engine started.
It's not getting gas peplace fuel filter didn't help. would like to know where gas line is. thanks
when you replaced the gas filter you had your hands on the gas line(pressure line).the return line runs along side of it(slightly smaller line).
2answers
Fuel line broen
Repair or change.
I need change gas filter, where are?
under car attached to fuel line comeing off gas tank follow line until you see it your gonna leak some gas remove clips holding it on dont forget to bleed fuel lines to get air out
The fuel line tube is leaking gas. how do i fix that?
exhaust the gas and make sure there is no more gas in the vehicle. Check the leaking line tube, and get the exact point that is leaking. But make sure you get the leaking point before draining or exhausting the gas.
If the fuel line tube is rubber, get an Abro Gum or go to any car part dealer store, you will get a gum that can seal up the leaking area or part.
But if it is a metal, you will have to take it to a welder or panel beater so that they can help weld or seal up the leaking line tube.
Good luck.
My car gas line broke and gas gushed out
if you can get to the break in the line you can do this your self for under $15.
get a tube cutter and cut the bad section of line out next take that section to the part store and ask them for fuel injection hose This is for high pressure fuel line and will work great for you) and fuel ingection hose clamps. now just slide the hose over the line at least an inch and use two clamps on each side of the hose.start the car and make sure it didn't leak. if no kleaks make sure the line is not hanging down. if so then tie them up with zip ties and your all done.
Replacing gas lines my gas line rusted thru under the driver seat is there an easy way to replace gas line
yes
get some steel line of the same size and 2 compression fittings cut out all the bad section till you have good clean lines on both ends and splice a new piece in.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
No gas to manifold,car will start adding gas to throttle body
yes gas should be coming out of the fuel line at the motor. if not the pump is bad. you will need to drop the tank to get to it as it is in the tank
Truck won't stay running
if it is a electric fuel pump take the fuel line off carburator and get a three foot gas line hook it up to the gas line on the car run gas line into an empty gallon container and turn key on and see if you are getting a good flow of gas
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
