Question about Razor Toys
When charging pocket razor with a car battery charger were do i connect cables n my scooter
    Top Expert:
  • Razor Master
  • 9,098 Answers
Connect to the battery.
Posted on Aug 28, 2015
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
ROB
  • 858 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
Anonymous
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
clsnyder
  • 5 Answers
SOURCE: When I plug in the charger is shows green, but the
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Posted on Apr 11, 2010
021480
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
Hannah Montana razor scooter says charged but wont go whats wrong
I haven't used my razor scooter in years. I just bought a charger and it seem like it is charging but it keep saying it is on low. I twisted the gas thing and it is making a noise like it want to go. But I am not sure I have charge it for 12 hours now. Do I need a battery or is it just taking it time to charge.
Sep 17, 2015 | Electric Razor Pocket Mod Scooter
Does switch need to be on when charging a razor pocket rocket?
No. The switch should be off before connecting the charger.
You can download a manual from Razor here...
http://www.razor.com/customer-care/owners-manuals/
Jul 14, 2014 | Razor E100 Electric Scooter
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Jun 21, 2014 | Electric Razor Pocket Rocket Ride-on...
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
Razor bella will not go?
one or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
May 29, 2012 | Razor USA Razor Pocket Mod Electric...
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
Just wondering if I can buy extra batteries and charge them without them being in the scooter and how hard is it to change out the batteries, my goal is for the kids to ride one one set while the other set...
Depends, some tabs are directly soldered to the batteries themselves so you will need a soldering iron to remove the tabs. After that, it wouldn't be too hard to remove and replace.
Keep in mind that these take 2x12volt batteries and these lead-acid type batteries may take a long time to charge depending on the current your charger is supplying.
If you plan to charge the two batteries with the stock charger, then you would have to wire the 2 batteries in series for 24volts (stock charger 24v) and for convenience you may also want to head out to your local electronics store to see if they have the female socket that the charger goes into, and possible some wire, connectors/tabs that attach to the batteries and possible some small alligator clips if required.
Nov 21, 2010 | Razor E300 Scooter
Toys Logo
59 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
