Expert
- Posted on Sep 03, 2015
Re: how can I tell if the cooler has gone bad
Most power steering pump's fluid doesn't run thru your cooler, there is a transmission cooler in front of your radiator or built into you radiator. If there was a leak there you'd see it under the truck around the transmission lines.. or around the metal lines than run into your cooler/ radiator.
