Xerox Phaser 8860MFP Printer Logo
J
John Elias Posted on Aug 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System error13,264.42:88656 - Xerox Phaser 8860MFP Printer
NICK FIRTH
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Xerox Expert 129 Answers
  • Posted on Mar 18, 2016
NICK FIRTH
Xerox Expert
Level 2:
Passionate:
Answers
129
Questions
0
Helped
110553
Points
234
That error signifies that the printhead reservoir is overheating and the printhead needs to be replaced. The part number is 017K04540 and can be purchased at www.iteminconline.com.
How many fuse boxes are there on a 2005 Toyota matrix XR
Engine compartment
Toyota Matrix - fuse box - engine compartment
Instrument panel
Toyota Matrix - fuse box - instrument panel
Fuses (type A)
Fuse Ampere rating Description 1 FOG 15 Front fog lights 2 HEAD LH UPR 10 Left?hand headlight (high beam) 3 HEAD RH UPR 10 Right?hand headlight (high beam), high beam indicator light 4 SPARE 30 Spare fuse 5 SPARE 15 Spare fuse 6 SPARE 10 Spare fuse 7 ETCS (1ZZ?FE engine with two?wheel drive models only) 10 Electronic throttle control system 8 AMP 30 Car audio system 9 MAIN 30 Starting system, "AM2" fuse 10 DOME 15 Car audio system, clock, personal lights, interior light, trunk light, open door warning light, wireless remote control system 11 HORN 10 Horn 12 HAZARD 10 Emergency flashers, turn signal lights 13 EFI 15 Multiport fuel injection system/sequential multiport fuel injection system, emission control system, "EFI" fuse 14 ALT?S 5 Charging system 15 HEAD LH LWR 10 Left?hand headlight (low beam) 16 HEAD RH LWR 10 Right?hand headlight (low beam) 17 EFI2 (1ZZ?FE engine with two? wheel drive models only) 15 Multiport fuel injection system/ sequential multiport fuel injection system, emission control system 18 TAIL 15 Tail lights, license plate lights, instrument panel lights, instrument cluster lights, clock 19 OBD 7,5 On?board diagnosis system 20 WIPER 25 Windshield wipers 21 AM2 15 Charging system, multiport fuel injection system/sequential multiport fuel injection system, starting system, SRS airbag system 22 STOP 15 Stop lights, high mounted stoplight, anti?lock brake system, shift lock control system, multiport fuel injection system/sequential multiport fuel injection system, cruise control system 23 DOOR 25 Power door lock system, glass hatch opener switch 24 AM1 25 "CIG" fuse 25 ECU?IG 10 Electric cooling fan, anti?lock brake system, traction control system, vehicle stability control system, brake assist system, shift lock control system, cruise control system 26 RR WIPER 15 Rear window wiper 27 A/C 10 Air conditioning system 28 INV 15 Power outlet (115 VAC) 29 P/POINT 15 Power outlet (12 VDC/ in the rear console box) 30 ECU?B 10 Daytime running light system 31 CIG 15 Power outlet (on the instrument panel) or cigarette lighter, car audio system, clock, power rear view mirror control, shift lock control system 32 GAUGE 10 Gauges and meters, air conditioning system, daytime running light system, charging system, auto anti?glare inside rear view mirror, power windows, cruise control system, rear window defogger, back?up lights, front passenger's seat belt reminder light 33 WASHER 15 Windshield washer, rear window washer 34 M?HTR/DEF I?UP 10 Engine control system
Fuses (type B)
Fuse Ampere rating Description 35 ABS NO.1 30 Anti?lock brake system, vehicle stability control system, traction control system, brake assist system 36 RDI FAN 30 Electric cooling fan 37 ABS NO.2 40 (without vehicle stability
control system) Anti?lock brake system 50 (with vehicle stability
control system) Anti?lock brake system, vehicle stability control system, traction control system, brake assist system 38 HEAD MAIN 40 "HEAD LH UPR", "HEAD RH UPR", "HEAD LH LWR" and "HEAD RH LWR" fuses 39 AIR PUMP 50 (1ZZ?FE engine with four?wheel drive models and 2Z ?GE engine only) Emission control system 40 HTR 40 Air conditioning system 41 DEF 30 Rear window defogger, "M?HTR/DEF I?UP" fuse 42 POWER 30 Power windows, electric moon roof
Fuses (type C)
Fuse Ampere rating [A] Description 43 ALT 100 Charging system, "ABS NO.1", "ABS NO.2", "RDI FAN", "FOG", "HTR", "AM1", "POWER", "DOOR", "ECU?B", "TAIL", "STOP", "P/POINT", "INV" and "OBD" fuses WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
1helpful
04toyata camry ecu b fuse keeps blowing
I see on this fuse box diagram below the ECU B, this is the description for that fuse.( could be a short somewhere in the circuit.) Multiplex communication system (power door lock system, security system, auto?door locking system, automatic light control system, headlight delay off system, tail light auto cut system, illuminated entry system, daytime running light system, wireless remote control system), air conditioning system
https://www.autogenius.info/toyota-camry-2004-2006-fuse-box-diagram/
System restore for systemx s51g23013ga3th0
System Restore or System Recovery?
System Restore does not delete your data.
System Recovery deletes everything and sets your system back to when you first purchased it.
To launch System Restore you can:
Windows XP - Click Start/Programs/Accesstories/System Tools/System Restore
Windows Vista - Click Start/Programs/Accessories/System Tools/System Restore
Windows 7 - Click Start then in the search box type "System Restore" (without the quotes) and the system will show you the link to click above in the search results.
For System Recovery - RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manuals for how to start the Recovery.
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
7helpful
2answers
What does po440 on a 2003 saturn vue mean with a service engine soon light on
That is a problem in the evaporative emission control system.
Could be anything causing it
Clogged filter in the charcoal canister
A leak in one of the vacuum lines
The purge valve not working,,,etc.
The best thing is to take it and have it checked out, they might have to do a smoke test to find the problem.
All they do is inject smoke into the system, if there is a leak the smoke will come out of it. All it takes is a pin hole in these emission systems to screw it all up.
8helpful
2answers
I checked the codes and one comes up its po446. i dont under stand what it mean so i cant fix it to get the light to go out.
P0446 Evaporative Emission System Vent Control Circuit.
The following are descriptions of all Evaporative possible codes:
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System Leak Detected (small leak)
P0443 Evaporative Emission System Purge Control Valve Circuit
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
P0447 Evaporative Emission System Vent Control Circuit Open
P0448 Evaporative Emission System Vent Control Circuit Shorted
P0449 Evaporative Emission System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission System Pressure Sensor/Switch
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P0452 Evaporative Emission System Pressure Sensor/Switch Low
P0453 Evaporative Emission System Pressure Sensor/Switch High
P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
P0455 Evaporative Emission System Leak Detected (large leak)
P0456 Evaporative Emission System Leak Detected (very small leak)
P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
At least the cap isn't loose for the gas tank.
I would clear the code with an OBD-II Scanner 'erase code' button, and see how long it takes for it to come back.
2answers
I'm trying to install a c4380 wireless printer with windows 7 but it won't take, says it's not supported by software
  1. First find out if you are using 32 or 64 bit
  2. Click Start
Collapse this imageExpand this image vistastartbutton.jpg , type system in the Start Search box, and then click system in the Programs list.
  1. The operating system is displayed as follows:
    • For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
    • For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type system in the Start Search box, and then click System Information in the Programs list.
  2. When System Summary is selected in the navigation pane, the operating system is displayed as follows:
    • For a 64-bit version operating system: x64-based PC appears for the System type under Item.
    • For a 32-bit version operating system: x86-based PC appears for the System type under Item.
  3. Then go to hp website and download driver for windows 7 for correct bit version.
  4. Unistall old driver install new.
1helpful
3answers
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
4helpful
Design a Menu-driven interactive programme to find out all the Capital cities of India using switch statement
import java.io.*;
public class capital
public static void main(String args[]) throws Exception
System.out.println("Enter 1 for Andra Pradesh");
System.out.println("Enter 2 for Arunachal Pradesh.");
System.out.println("Enter 3 for Assam.");
System.out.println("Enter 4 for Bihar.");
System.out.println("Enter 5 for Chhattisgarh.");
System.out.println("Enter 6 for Goa.");
System.out.println("Enter 7 for Karnataka.");
System.out.println("Enter 8 for Gujrat.");
System.out.println("Enter 9 for Haryana.");
System.out.println("Enter 10 for Himachal Pradesh.");
System.out.println("Enter 11 for Mizoram.");
System.out.println("Enter 12 for Jammu & Kashmir.");
System.out.println("Enter 13 for Jharkhand.");
System.out.println("Enter 14 for Kerala.");
System.out.println("Enter 15 for Madhya Pradesh.");
System.out.println("Enter 16 for Maharashtra.");
System.out.println("Enter 17 for Manipur.");
System.out.println("Enter 18 for Meghalaya.");
System.out.println("Enter 19 for Nagaland.");
System.out.println("Enter 20 for Orissa.");
System.out.println("Enter 21 for Punjab.");
System.out.println("Enter 22 for Rajasthan.");
System.out.println("Enter 23 for Sikkim.");
System.out.println("Enter 24 for Tamil Nadu.");
System.out.println("Enter 25 for Tripura.");
System.out.println("Enter 26 for Uttar Pradesh.");
System.out.println("Enter 27 for Uttaranchal.");
BufferedReader br = new BufferedReader(new InputStreamReader(System.in));
String read = br.readLine();
int ch = Integer.parseInt(read);
switch(ch)
case 1: System.out.println("Hyderabad");
break;
case 2: System.out.println("Itanager");
break;
case 3: System.out.println("Dispur");
break;
case 4: System.out.println("Patna");
break;
case 5: System.out.println("Raipur");
break;
case 6: System.out.println("Panaji");
break;
case 7: System.out.println("Bangalore");
break;
case 8: System.out.println("Gandhinagar");
break;
case 9: System.out.println("Chandigarh");
break;
case 10: System.out.println("Shimla");
break;
case 11: System.out.println("Aizawl");
break;
case 12: System.out.println("Srinagar(Summer) & Jammu(Winter)");
break;
case 13: System.out.println("Ranchi");
break;
case 14: System.out.println("Trivandrum");
break;
case 15: System.out.println("Bhopal");
break;
case 16: System.out.println("Bombay");
break;
case 17: System.out.println("Imphal");
break;
case 18: System.out.println("Shillong");
break;
case 19: System.out.println("Kohima");
break;
case 20: System.out.println("Bhubaneswar");
break;
case 21: System.out.println("chandigarh");
break;
case 22: System.out.println("Jaipur");
break;
case 23: System.out.println("Gangtok");
break;
case 24: System.out.println("Chennai");
break;
case 25: System.out.println("Agartala");
break;
case 26: System.out.println("Lucknow");
break;
case 27: System.out.println("Dehra Dun");
break;
default: System.out.println("Invalid entry!");
break;
(IGNOU - BCA - CS-74 - Q.4 - 2009)
Visit : Www.hamidraza.page.tl
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
