Computers & Internet Logo
A
Anonymous Posted on Aug 26, 2015
Do these have a wps button? - Netopia Computers & Internet
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on Aug 26, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1198208
Points
47629
Honestly, no idea. If you don't have a manual with the MODEL you can try to look for the proper one,
I got some links, maybe one is yours:
http://www.netwood.net/support/manuals/Netopia-3347W-ENT_qsg.pdf
http://www.netwood.net/support/manuals/Netopia-2247-62-User-Guide-US-EN.pdf
http://videos.cctvcamerapros.com/pdf/netopia-router/Netopia-Router-Manual.pdf
There are more....
Now, take note that WPS is too easy to hack. Read some about this issue:
How to Hack Wi Fi Breaking WPS PIN to Get the Password with Bully
And read more about theme...
Where is the WPS button on Harman Kardon ASTRA
There is no WPS button on the Harmon Kardon Astra. The Astra has a Bluetooth pairing button on the top above the action buttons.
Wireless routers can have a WPS button that you press to setup an internet connection when a device is set to look for available networks. Depending on the model, I've seen the WPS button on the back or side of the router. If there is no WPS button, then you have to know the SSID broadcast by the router and the password.
The quick start manual for the Astra is available here: https://fccid.io/APIHKASTRA/User-Manual/Users-Manual-3815317 .
I hope this helps. Please add a comment with the model number of the router, if you'd like me to locate the WPS button on your unit.
(Note: the WPS button does not work with some older password encryption options.)
Where to find wps pin on canon mx494 printer
Hi Mbali, PIXMA MX494 Wireless Connection SetupSome access points (sometimes referred to as routers or hubs) feature an automatic connection button labelled "WPS" which stands for Wi-Fi Protected Setup.This allows permitted devices such as your PIXMA MX494 to connect to your network without needing to enter a password and it enables a quick and easy method of connecting your devices.This method is by far the easiest way of connecting your PIXMA MX494 so if your access point has a WPS button please select the 'WPS Connection Method' tab below for instructions on connecting using this method.If your router does not support WPS we have provided alternative instructions to get your PIXMA MX494 connected so please select the 'Standard Connection Method' tab below.Back to topWPS Connection Method Standard Connection Method Restore to Factory SettingWPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.Press the [Setup] button (B) on the printer. Use the arrow buttons (C) to select [Device settings] and press the [OK] button. Use the arrow buttons (C) to select [Wireless LAN setup] and press the [OK] button. The printer will now automatically search for access points supporting the WPS feature. The following message will be displayed on the printer's screen "Press WPS button of the wireless router about 5 sec. and press [OK] on this printer" Press and hold the [WPS] button on your access point for approximately 5 seconds, then release. For exact instructions on starting WPS on your access point, please refer to its user guide. Press the [OK] button on the printer within 2 minutes. Once connected, the following screen will appear. Press the [OK] button to complete the setup.
Thanks
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
1helpful
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
I cannot find my WPS button on my Wifi printer. I have pressed WPS on router but no different
Dec 27, 2012 - It asks for me to push the WPS button, but can't find? ... Now I am afraid to unplug the printer and move it back to my desk because it will ... starting only 2 days back, it was daily "dropping" my wifi connection with my MacBook.
WPS access point - Canon Community
community.usa.canon.com/t5/Wireless.../What...WPS.../11819
Jan 19, 2013 - What and where is the "WPS access point" button required to set up wififor the ... What and where is the "WPS access point" reqired to use wifi for the MX432printer .... My WPS button is on my the back of my router (blue button) ... I have a tp-link model tl-wr841n and I can't find the access point in the router ...
Connecting your HP wireless printer ' Wireless Printing ...
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
To adapt N300 Wireless Adapter, I need to press the WPS button on wireless router or gateway. Unable to locate WPS button.
The reason you may wish to press a WPS button is to connect to a WiFi network. The WPS button will be on the router, not on your computer. If no WPS button on the router you will need to enter the WEP/WPA password to connect to the router.
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Where is the wps button
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
