Question about DeLonghi ECO 310.BK Pump Espresso Maker Appliances Cookware - Black
Why is it leaking during operation?
Machine still functions but takes more time. Machine is 5 years old.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 819 Answers
Could need de-scaling. Scale builds up after time and reduces flow rates, increasing pressure leading to leaks. Give it a go with any generic de-scaling powder or liquid following the instructions. My coffee machine (different model) did similar and now works like new again.
Posted on Aug 26, 2015
SOURCE:
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Why is my maytag 2000 washing machine leaking from underneath when it is only 2-1/2 years old
You need to establish the area that you have seen the water pooling and trace it back if possible.Make sure you disconnect the machine from the power point before you conduct these checks. Is the water clean, dirty or oil contaminated. if you can't determine exactly where the leak is coming from try placing a chux cloth around a hose with a cable tie before a wash then check it on the completion of the cycle - make sure the chux cloth does not effect the operation of the machine.
Oct 20, 2014 | Maytag Washing Machines
Problem with my rapid bake function
Disconnect and reconnect to see if it corrects its self.
Sep 17, 2017 | Black & Decker Kitchen Appliances - Others
I have the front loading Maytag and was using HE soap but with maybe too much Shout detergent to clean some stains. for the first time with my maybe two year old machine, some limited suds came from the...
Hi Mike. I am Kelly. I noted you went the chat route first before your p;ost ended up here.
Take the drain hose from the drain and maually drain the machine until you can not get any more water out of it. Then unplug the machine for 5 - 10 minutes so that the filter sensor will reset. For some unknown reason it seems the sensor is working but it did not trip and error code on the display panel.
If it still does not work after the manual drain you may have to open the filter door and open the filter to allow it to completely drain and do the same 5 - 10 min plug out of wall / power off routine.
Kelly
Mar 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
WANT TO BUY A SECOND HAND M29 SELECTRON 2 GROUP- LA CIMBALI
The price for the m29 select new is about 5500 to 6000. So for one of 4-5 years you can give about 2500-3000. However I sugest to open the machine and check if their are rusting points or any leaking points which propably be white points from calcium color. Also ask if their were any water filter like everpure or and a water softener conected to water supply of machine during the operation of the machines.
If you see minor points as above and the water was treated before entering the machine then your machine can work for minimum another 10 years.
Water calcium (scale) is the biger enemy of the machine.
Good Luck
Mar 10, 2010 | Espresso RMI La Cimbali Espresso Machine
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Leaking westinghouse 9.5kg washing machine
a hose has partially come off or a cut in the hose
Sep 06, 2009 | Westinghouse Washing Machines
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
DeLonghi ECO 310.BK Pump Espresso Maker Appliances Cookware - Black Logo
90 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
