DeLonghi ECO 310.BK Pump Espresso Maker Appliances Cookware - Black Logo
W
WILLIAM REYNOLDS Posted on Aug 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine is leaking water during operation...does it need new O-ring???
It is a BAR 15
Steve Luck
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 819 Answers
  • Posted on Aug 26, 2015
Steve Luck
Master
Level 3:
Dedicated:
Answers
819
Questions
0
Helped
219072
Points
2252
O rings do deteriorate over time but see my other answer as it is possible it just needs de-scaling.
DeLonghi Magnifica is leaking water from the bottom whenever I make a cup
I just fixed a similar problem with my Delonghi Eco 310. Halfway through making a cup water stopped coming out but ran out from underneath.
This is how i fixed it:
First I checked the little tube that goes from the pump and anti drip valve into the boiler unit. There is a clamp on both ends to remove before you can take it out. First fault can occur here, check the black little O-Rings that might still stuck inside the connectors, if they are worn out they might need replacing.
Then check the little tube for any damage, even any fine tiny cracks can lead to a big leak as 15 bar go through it.
In my case there was no damage there, also not on the tubes that come from the watertank into the pump.
After I checked all that and it seemed fine, I turned the machine back on again with open top (careful of any electrical contacts!!!). Then I saw that water and steam came out of the anti drip valve. It seemed the water got sucked into the pump, pumped into the boiler, heated up there and put to 15 bar, but because the valve was broken the water didnt actually came out but searched the easiest way, which was the broken valve, that regulates the pressure. I went on a site for delonghi spare parts, bought a new valve for £5, replaced the old one and -tadaaaa! It works again!
Water is leaking out drain during cycling; cubes are thinner than normal. Does water valve need to be replaced or check rubber gasket?
Just above the pump there is a check valve that may be stuck open
during operation which will cause thin ice. Also make sure you have the o-ring on the bottom of the drain tube if it was removed during cleaning.
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
1helpful
2answers
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
2helpful
2answers
Steam/water valve leaks water, only fills coffee to 50%, help? I have completely removed steam valve assembly to clean and reassemble. Leak persists, suspect o-rings?
Hi
If your water valve is cream or black colored, you need a new manifold. They will get hair line cracks if you steam, but don't cool them down after steaming by running cold water through them. If you have one of the new brass(silver) manifolds it could be your O-rings but i doubt it.
During the spin cycle the washer started turning off and then on repeadedly and then it just shut down completely and now will not turn on, any idea what the problem is?
Replaced water pump, found 2 quarters located within the old water pump which destroyed the o-ring causing a small leak and hindered the operation of the entire machine.
1helpful
2answers
Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
2answers
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
2answers
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
7helpful
2answers
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
