FCC ID: PPIRM-217 TYPE: RM-217 MODEL: 6300
SOURCE: security code
we cant fix it here,., but here's how.. in the service center they'll put cables in your fone , run the soft and reset your security code....a word of advice dont publish your imei.....somebody can mess it up....
SOURCE: hi i forgot my nokia 6300 security code and now i cant access my phone. pls help
IME no. of my nokia 6300 IS 353932011514376
PLZ TELL THE SECURITY CODE
SOURCE: i can't open my 6300
1. first install phoneix service
2. open it
3. In Phoenix, click File>Manage Connections.
4. Now click New.
5. Now select the type of cable you are using. If you are using DKE-
2, CA-53 [N-Series] cable, select USB.
6. Click Next. It will find your product and say FOUND. If it doesn't
find any, you can try changing your cable type by clicking Back.
7. Click Next and then Finish.
8. Now your cable type [USB] appears in the connection list. Select
it. Click APPLY and then CLOSE.
9. Now select File>Open Product.
10. A list of RM code will open. Select your phone's RM code. Like
RM-133 for Nokia N73. Click OK
11. Now select File>Scan Product.
12. Your phone's firmware info will appear at the extreme bottom of
the Phoenix window.
13. Now go to Flashing>Firmware Update.
14. A window will open.
15. On that window click Browse button [the one with three dots].
16. A window will open with various products and various regions.
Choose the region or country of your choice according to the
language pack you want to install.
17. Click Ok.
18. Click Refurbish.
19. Now your actual flashing has started. Don't touch your phone or press any button until the flashing has finished. Also don't touch your data cable and your computer system.
20. At the end Phoenix will tell you to remove your phone as the
21. Now wait for your phone to reboot into latest firmware.
22. The flashing procedure takes 8-9 minutes, a lot faster than Nokia
Software Updater.
Flashing dead phones [Which show only white screen on startup
this will reset your password
SOURCE: my phone NOKIA 6300 TYPE RM-217 FCC ID PPIRM-217 asks me code for putting other sim
Your nokia is locked with network provider.So whenever you insert a other country sim card, your mobile ask the unlocking code.You can get this code from Superunlockcodes.com .This will help you to unlock your mobile easily.
