All my controls work, but I get no heat from the top or bottom elements, I get no F fault codes but do get a PF code when I cycle the circuit breaker and it go's off when you set the time!, if the EOC is bad will it show a fault code ?.
The exploded parts diagram can be found here: http://www.searspartsdirect.com/model-number/PLEB30S9FCC/1428/0125300.html. Look for part designation 119. It is a **resettable** thermal switch. There is a little red button on the top that you press in and feel/hear a click of the breaker being reset. The part number is 318004900. You will have to remove the oven from the wall, remove the back cover panel and locate it. If you are unsure or hesitant about doing any of this, CALL FOR SERVICE!
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
