Two locksmiths tried to open car doors but no go there has to be a secret trick to open it
SOURCE: My DVD drive does not open
I suggest you may have accidently put another disk in your DVD drive on top of the one used previously without removing it first: I know, I did just that, and the teeth may now be sheared on the drive wheels which means it will probably need replacing with a new one.
To open manually, look for the tiny hole beside the Open/close button just under the drawer and insert a long slim steel probe which will activate a switch to open the drawer. (Have a look among your kitchen utensils, there might be something there).
Hope it works, but you may find you need a new DVD/RW unit, so have a look around in the New Year Sales and use the opportunity to buy the best you can find at a bargain price.
Raydot
SOURCE: Driver side outside door handle does not work
the trim should just pop off with a screwdriver but make sure you have all the screws taken out first
SOURCE: cant open the glove box
No trick, it is most likely locked, use a putty knife an pry it open carefully near the center where the latch is, it will pop open
SOURCE: lost ignition key
be for you replace ignition key. try going to a ford dealer.bring your reg and see if they can punch a key out for you. if not try to find a lock smith to make a key.if no luck you can replace it the switch cost about $25.00
SOURCE: My electronic key has been lost and my valet key which used to work, won't unlock the door.
I found the automatic key in my wife's car. Thanks
Hi Frances Braudaway, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
