cleaning the DVD player will help it read the disc, because a DVD player does get dusty. also it might be the disc, some DVD players will not accept some disc.
This can be caused by several different things. It may be the read head assembly needs to be cleaned, the disc cannot be recognized. Or it could be a disc format which the player does not work with. Check the owner's manual for compatible disc formats. the Disc may be damaged or needs to be cleaned. The disc may need to be finalized by the recorder it was recorded on if a recordable disc. This is not the case for DVD-video as these are stamped discs.
You can try a cleaning disc but it may not solve the problem. Inspect and clean the disc and try again. Having the disc head assembly cleaned may be the answer but the service cost could be more than just buying a new player.
All players need cleaned from time totime. Do NOT try to clean it with anything other than a CD / DVD lens cleaner. They are available almost everywhere that sellsBlank media. It will clean the lens without scratching or smearing it.
It's unable to read the source disc.Try using a comerically recorded disc.Try several different ones.Use a disc cleaner to clean the laser if all else fails
Id the disc clean of debris dust and scratches? Cleaned the unit aswell with a blue ray cleaning kit? Please do these things, if you find this helpful please use Fixya when rating Thanks
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
