I have checked the fuses
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at [email protected] hope this helps you
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
SOURCE: CD stuck in CD player. Cassette and radio works good. But CD stuck.
This symptom is often a sign the player is nearing its end of useful
life. But, sometimes it is merely due to a collection of dust, dirt or
a foreign object lodged in the mechanism. Sometimes it is a logic
error inside the electronic memories.
So, there are a number of possibilities.
Here is what I would do:
ONE: Do NOT force it or use tools to pull the disc out.
TWO: If you can find the wires that supply the 12 volts to the unit,
pull that wire so there is no power to the unit whatsoever for at least
30 seconds. That will reset the electronics inside the player.
THREE: IF you cannot find the wires, or if they are too hard to get to,
you can pull the plus cable off the battery; raise the hood and with a
wrench loosen the bolt holding the plus cable onto the battery
terminal. Pull it off for at least 30 seconds or longer, then put it
back on. This will perform a hard reset as in TWO.
FOUR: If still no removal try this technique:
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
If it is not an expensive unit you may find it a superior investment to
purchase a new player rather than pay a tech to repair it. (In the
worst case the unit must be pulled, cover removed and disc manually
removed; then you may find out there are damages or defective circuits
awaiting further repairs; probably looking at a charge of $75 or more
if you go to a service shop).
Let's hope the ideas above kick it out and it returns to normal useage.
SOURCE: cassette players jammed
actually you can not lubicate the cassette players. it has to do with a belt inside. your players may need to be demagnitized. i would go to radio shack or electronic store and try a cassette cleaner/demagnitizer and see if that solves the problem. i would even try different batteries or a ac power adapter if you have the plug. some batteries make units run slow. i would even get a can of dust cleaner that you find in the electronics section. you spray it in and it cleans the inside of the dust that may be inside.
SOURCE: I have a 2000 ford taurus ses my radio, tape
You might try testing the power that leads into the insturment panel. You can remove the hole radio assembly by bending a wire coat hanger enough to get it into the two holes on the sides. When you pull it out, you will have depressed a couple of clips. The power switch is connected to the left side in the back of the unit. Hope this helps.
