Coffee grinds cleaned now drawer won't go back in
If the display is showing Malfunction while this is happening, it might be having trouble emptying out the grounds into the tray, Mine does this periodically, but it seems to be more related to the beans as I have spells when this happens (I always use the same brand of beans, so I think sometimes the beans have more oil than other times causing the sticking grounds. Remove the tray and lift out the container for the grounds. Reinsert the flat tray and the machine should once again try to clear itself. If it is showing Malfunction 9, I unplug the machine for a few minutes. With the grounds cup still removed, I plug the machine in and turn on again. Most times the malfunction clears and the grounds end up in the liquid catcher tray. I then remove the tray and put the container for the grounds back in and continue normal use.
Fish that obstacle out.
