For the Galanz 1.2 cu. ft. ToastWave, GTWHG12BKSA10, you need to press and hold the Clock/Timer pad for 3+ seconds. If needed, press again to switch between 12 and 24 hour clock options. Then rotate the dial until the correct hour is displayed. Press one of the following: the dial, Start or Clock/Timer to save the current hour. Rotate the dial to set the current minutes. Again, press the dial, Start or Clock/Timer to save the current minutes. To exit the clock setting mode, press Stop/Cancel.
To set the time display, the steps usually are to first turn off the microwave oven completely. Then power it on. Touch the "Clock" or "set time" pad and key in the current time. Press the set pad to lock the time.
how old is it??,, sometimes electronics go out due to age or lightening storms, but you shud be able to find the same model or newer model here>>>www.discountbargainprices.com
To set the clock, press
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
