Microwave quit working so I reset the breaker but still had no power. Outlet works for other appliances so it must be the fuse?
It depends on the type of oven. On countertop models, remove the outside cover. On over the range units, remove the control panel. You may have to remove the air deflector on the top first in order to gain access to the control panel screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
SOURCE: Control Panel of Maytag Microwave CMV 1000B doesn't work
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
If you would like to
have us do this repair for you, we do that for $39.95 plus part costs.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: We were defrosting meat yesterday and the
Sorry to read about your problem, I hope this helps you out.
Their are fuses and other issues, that can cause your issue's
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
SOURCE: MCO160 microwave and cook vent appliance
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
SOURCE: we have magic chef Over the Range Microwave Oven Model: MCO153U. Microwave was dead and no power
Bad door switches normally don't cause fuses to fail. Typically there's 2 of them wired in series with each other so if one of those switches fail to turn off power the other one will when the door is opened.
There are a number of components that can cause a fuse to open; HV diodes, capacitors and fans, to name the most common culprits, and require the knowledge and safe use of a volt-ohm meter to efficiently find the problem.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
