Philips 47PFL7403D 47 in. LCD TV Logo
Posted on Jul 12, 2009
Same problem Exact same issue here - i have a 42" LCD (42PFL360) and will often be startled by the sudden, loud, constant static that springs from the TV with no warning. It normally happens after being on for several hours but sometimes after only a short period. I wonder if it does any damage to the speakers given the high volume.....
  • hannah marie Sep 12, 2013
    i have a dynex 42" lcd flat screen and mine does the same thing. we have to unplug our tv for it to stop. we have everything plugged into a surge protector but it still does it constantly now. thought about replacing the tv but now i see a whole bunch of brands do it too so now i dont know what to do... ugh :(
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
419
Points
Do you have to turn the TV off and then on again to get the sound prob to go away? Our sound problem happens 10 to 15 x per day depending on how long the TV is on.
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Green/ red pixels on screen. tv making annoying
If the unit has not previously had the PSU or Y-SUS boards replaced prior to this issue. Then it sounds like the voltages are off on one of those two boards. There is a process for checking those voltages and trying to adjust them. If those boards were recently replaced I would say the tech did not check voltage accuracy. But if it just happened out of no where go with the Y-SUS board as the problem. I say that because the unit powers on.
1helpful
How do I fix bad static? Dell W3706MC 37 in. HDTV LCD has been fine and suddenly the sound has loud static on all sources. Is this a sound circuit failure?
Yes,loud static usually comes from bad isolation of sound signal path so it's probably a frayed cable or a loose jack. Or if you're unlucky some parts inside have failed.
1helpful
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Sony 42" Grand Wega makes noise constantly when running
That is correct, it would be fan noise and fan will be replaced.
Let me know exact model number to help you in finding fan in parts stores.
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
1helpful
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
AKAI LCT3285TA static noise
Which input connections are you using?
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
