Mercedes-Benz 2010 ML350 4MATIC 3.5L Logo
A
Anonymous Posted on Aug 07, 2017
2010 Ml350 no daslights no start
2010 Ml350 electronic ignition module failures and repair tips After inserting key fob no dash lights, no start, after 5-10 times cranks and works normaly. Often both ofthe key fobs are not detected no warning on the cluster , but nothing happens in socket. sometimes starts with dashlights normally. I was told that it may be ignition module failure. What may have failed and How to fix it thanks .
3 Related Answers
Anonymous
  • Posted on Jul 08, 2010
SOURCE: 1997 C200 Key Fob Failure
Max, how did you fix your problem? The same thing happened to me today and I have to call the dealership I assume. Thanks, Judy
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Dec 27, 2010
SOURCE: Merc CLK 320 (2003) - key fobs worked this
Sorry but my alldata book is stating they can only be re programmed with dealer diagnostic equipment
Anonymous
  • 14553 Answers
  • Posted on Dec 17, 2012
SOURCE: Starter motor not turning over when key is turned
Have a mechanic look but it sounds like the bendix which spins the starter is bad, usually if bad exactly what you are describing. When you try to start it engages and in a lot of cases if just a click and then will work at other times it is the problem---If the starter has been there for a while replace it and the bendix which almost always come as a unit.
2010 Mercedes M-Class ML350 4MATIC. Intermittent key fob recognition and delayed start problem.
Rony
You need an auto electrician with a pro grade scan tool computer to diagnose. Those cars are so complicated. It may be the immobilizer.
2answers
Is there a recall on 2004nissian maxium key switch car wont start
your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your buick dealer to get a new one,they are programmed for each car only,you cannot bypass it.
1helpful
2answers
Erratic electrical behavior
need to reprogram the key fob to the car.. its memory is crashed..also have the ecm looked at..electrical control module..
2helpful
Key loose / does not stick in ignition slot
Diagnosis: Basically, the ignition slot thinks the key is in so the lock mechanism is in place, which prevents the key fob from going in all the way.
Solution: Insert your finger all the way into the slot. Curl your finger slightly so that the tip touches the bottom. Pull your finger out slowly and your finger will "unlock" the mechanism. You will hear a click sound and also feel it being unlocked. Try inserting your key fob into the slot.
7helpful
Resetting a Key fob on 2007 Honda Pilot
to program a key fob- get in vehicle and close all doors. insert key into ignition, have all the key fobs you want to program for this vehicle in hand, programing erases all old fobs. turn the ignition switch to on(all dash lights light up, on click before starting the car). then hit the lock button on one of the fobs. turn the ignition to lock. turn the ignition back to run and press the lock button again from the same remote. repeat untill all the locks cycle. ones the locks cycle keep the ignition in run and press the lock button on each key fob(the ocks will cycle each time a button is pressed). then turn the ignition to lock after all fobs have been programed
2helpful
Need to reset the key fob after replacing the battery
You should not have to reset the key fob after a battery replacement. The signal from the key fob stays the same and is programed to the reciever.
If the key fob needs to be reprogrammed then follow these steps.
1. Have all key fobs with you during programming.
2. Sit in the vehicle with all doors closed.
3. Lock all doors using the Lock/Unlock switch on the door.
4. Insert and withdraw the ignition key 7 to 9 times within 10 seconds (do not turn the key, just insert and withdraw).
5. The 4 way flasher indicator on the dash should flash once or twice.
6. Insert the ignition key and turn it on (key on, engine off).
7. Press any button on one remote and the 4 way flasher indicator on the dash should flash once.
8. If you have more key fobs to program use the Lock/Unlock button on the door to unlock the doors and then lock the doors.
9. Press any button on the next key fob and the 4 way flasher indicator on the dash should flash once.
10. Repeat if you have more key fobs. Only 5 can be programmed.
11. To exit, simply turn of the igniton and remove the ignition key.
12. Unlock the doors using the Lock/Unlock switch on the door and exit the vehicle.
13. Make sure the window is down when testing remotes in case you leave the keys inside.
14. Close all doors and test all remotes that were programmed.
Do not skip any steps or the process will not work.
If the 4 way flasher indicator does not work when inserting the key, you will need to start the process from the begining. If it still does not work the receiver may be your problem.
If the 4 way flasher indicator does not flash when pressing any button on the key fob then the key fob is the problem (dead battery or defective remote)
2helpful
My 2001 jaquar s-type every two weeks car won,t start new batt,nothing draining elect sys,alt ok,car will not start if you jump battery,car will start if you put jumping cables on alt and ground other to...
The S Type is similar to the Lincoln LS.
These are TSBs that address battery drain on the LS.
Partial TSB
Article No.
02-9-5
  • ELECTRICAL - BATTERY DRAIN DIAGNOSIS - SERVICE TIPS
Publication Date: APRIL 30, 2002
FORD: 2002 THUNDERBIRD LINCOLN: 2000-2002 LS
ISSUE: Some vehicles may exhibit excessive electrical system current draw which could result in a discharged battery and a no crank condition.
ACTION: Use the following Service Tips to monitor the vehicle electrical system for excessive battery current drain and repair as needed. Refer to the following Service Information Tips for details.
SERVICE INFORMATION Having a firm grasp on the design and normal operation of the electrical system will aid in properly diagnosing and repairing any faults with electrical components and/or circuitry. When the vehicle is at rest (ignition key turned off and removed), some amounts of battery current drain will be present since many of the modules and electronic components in the vehicle require this to sustain memory and system monitoring. The Powertrain Control Module, Antilock Brake Module, Electronic Automatic Temperature Control Module, Front Electronics Module, Rear Electronics Module, Driver Door Module, Instrument Cluster Module, Roof Opening Panel Module, Heated Seat Module, Driver Seat Module, Cell Phone Module and Vehicle Emergency Message System Module all have power supplied at all times for this purpose. Many of these modules monitor activity and communicate with each other through the Standard Corporate Protocol (SCP) Link. When the ignition key is first shut off and removed, the vehicle is exited and the doors are closed, the electrical system goes into "stand-by" mode, where the Rear Electronics Module (REM) and the Front Electronics Module (FEM) keep the System Switched Power (SSP) relays activated. After a minimum of 45 minutes, the REM and FEM will power down to prevent battery discharge. Power down mode occurs when the REM and FEM "time out" and release the ground on all 4 (four) of the SSP relays. The SSP relays are wired in a fashion in which they are either all on or all off. In other words, the SSP relays cannot be operated independent of each other. If power down does not occur, because of a system fault or errant SCP Link activity, the REM and FEM will remain energized along with the SSP relays and the other electrical devices that they provide power. The REM and FEM provide power and ground to devices such as exterior/interior lighting and many of the body modules in the vehicle. The Wiring Diagrams Manual may be referenced for additional information on the SSP relays, the REM and FEM, in Sections 13 & 59. Once the REM and FEM enter power down mode they will not energize the SSP relays until they are commanded to "wake up" by one or more of the following commands:
  • Key Fob Activity (Any Command)
  • Door Ajar (Any Door)
  • Luggage Compartment Ajar Switch
  • Drivers Power Seat Switch
  • Power Tilt/Telescopic Steering Column
  • Headlamps/Park Lamps On
  • Key In Ignition
  • Key On Ignition
  • Anti-Theft Hood Switch
  • Brake Pedal Position Switch
  • Memory Seat Switch
BATTERY DRAIN DIAGNOSIS -------------------------------------------
1helpful
REMOTE KEYLESS ENTRY 99 GRAND CARAVAN
INSTALLATION: REMOVE THE TOP DASH COVER USING A FLAT TIP SCREW DRIVER AND LOCATE THE CONNECTOR FOR THE RKE MODULE. THE CONNECTOR WILL BE SMALL AND LOCATED NEXT TO THE HVAC DISTRIBUTION DUCT. MOUNT MODULE AND INSERT THE CONNECTOR. SINCE THE BODY CONTROL MODULE IS INVOLVED WITH THE RKE THIS MAY OR MAY NOT WORK BECAUSE NOT ALL CONTROLLERS ARE THE SAME BUT IF YOU WOULD LIKE TO TRY TO PERFORM THE TASK TRY THIS. FOR PROGRAMMING:
  1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System.
  2. Insert ignition key into the ignition switch.
  3. Turn the ignition switch to RUN position without starting engine.
  4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds)
  5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s)
  6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful.
  7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total)
  8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s)
  9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Top Mercedes-Benz GPS Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
